turbo set up?
Old Oct 11, 2006 | 05:39 PM
prideofpoco's Avatar
prideofpoco
turbo set up?
Hi everyone,
I have a chance to pick up a turbo set-up for a 7.3 idi. I presently have a 6.9 idi. This kits has everthing with the exception of the y-pipe. It is a kit made by Canadian Turbo Sytems and I cannot find any info if they still exist. The turbo itself is a Schwitzer/borg warner. I do not know if I can find a pipe that is factory that will fit or I would have to get one fabricated up?
Thanks
Old Oct 11, 2006 | 05:46 PM
Agemenon's Avatar
Agemenon
You should be able to find a pipe that fits it, or go to a machine shop and have one made for you.
Old Oct 11, 2006 | 06:01 PM
Hamberger's Avatar
Hamberger
The Y pipe is not the simplest piece to be missing. You can probably order a factory Y-Pipe from ATS, be prepared to spend a few $$$$'s. Here is their address:
http://www.jhdiesel.com/ats.htm
ATS also has a direct web-page but you may have difficulty buying from Canada. I checked a while back and the closest ATS dealer to where i live was in Washington State.
Fabricating you own cross-over pipe is not a simple task. Lots of bends and twists. (look at the picture in the above webpage)
bEST OF LUCK...
sEB....
Old Oct 11, 2006 | 06:38 PM
bigblu78's Avatar
bigblu78
CTS was a system that was sold by Rob Blair from Kamloops, BC. The kit was offered by many Ford Dealers in Canada in the late 80's through early 90's. Parts are no longer made for the systems though I have heard that you can still find bits and pieces in small town dealers throughout Canada. Like Hamberger stated, you will more than likely have to buy an aftermarket ATS pipe if it will work or find a GOOD exhaust shop to fab one up for you.
Old Oct 11, 2006 | 09:19 PM
Spectramac's Avatar
Spectramac
I've got a CTS on my truck. I can't see anything from ATS working on it. You could probably make something using your original y-pipe. Where it comes back on the right side, curve it up then forward to go over the bellhousing. About a foot or so from the turbo flange it's necked down to a smaller size pipe, I guess to make it fit between the cab seam and the engine. The factory CTS pipe uses a nice Y collector where the two pipes join, but I doubt it makes much difference when it is so restricted up at the turbo. Mine builds all sorts of boost (18 psi), but doesn't have near the power of an ATS system.
Old Oct 11, 2006 | 11:19 PM
prideofpoco
thanks for all the replies, I will have to ponder this one for awhile.
Old Oct 12, 2006 | 11:33 AM
Spectramac's Avatar
Spectramac
So, does the kit have the down pipe with it, or would you have to make it too?
Old Oct 13, 2006 | 10:23 AM
prideofpoco
it does have the down pipe
Timf350
WTB - Parts & other
Nov 6, 2014 10:07 PM
bluethundersowner
32
Jul 13, 2014 01:32 PM
J0244
Mar 23, 2014 10:06 PM
chipper
Jan 29, 2008 09:01 AM
allyn63
General Diesel Discussion
Jun 22, 2006 08:56 AM
