1965 Rating Plate
Old Jun 4, 1999 | 06:14 PM
Russell Leonhardt's Avatar
Russell Leonhardt
1965 Rating Plate
Color I
Trans A
Axle 08
Vehicle ID F10DE625622
Thank You ole65!
Old Jun 5, 1999 | 04:47 AM
76highboy's Avatar
76highboy
1965 Rating Plate
Old Jun 5, 1999 | 09:04 PM
Stock Man
Guest
Posts: n/a
1965 Rating Plate
Vehicle ID F10DE625622:
F10= F-100 2 wheel drive
D = 8 cyl 352 2v
E = Built at Mahway, N.J. Plant
625,622 = Consecutive Unit No. The trucks were numbered in 1965 starting at 580,001 (first truck built) through 732, 000 (last truck built).
Transmission Code (A):
3-speed Manual Trans. Built by Ford
Axle Code (08):
Single Speed 3.50 Ratio rated at 3,300 #
Ford Built (Axle Tag ID WDM-B)
I hope this helps.
Stock Man
1967 Galaxie 500 Convertible (I need factory rims)
1967 F-250 FE 390 4wd
<a href="http://members.aol.com/tbeeee/page/index.htm">http://members.aol.com/tbeeee/page/index.htm</a>
Old Jun 8, 1999 | 07:06 PM
ole65's Avatar
ole65
1965 Rating Plate
It appears that you have gotten most of your inquiry handled by another with more free time than I. Regarding the color I, there is nothing listed for that. Check the stamping again, some are light and/or crooked. If it is an L then that would be dark green, a J would stand for red. None of other letters are feasible choices. The other possibility would be a special order color. I had one on a 79 F100 which would not decode; turned out to be a T-bird color. By the manual decoder, a D engine is a 352 four barrel; but the carb section only shows two barrel applications for 352s with the four barrel reserved for other V-8s. Interesting.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
