Believed windshield leak
Old Oct 11, 2006 | 08:05 AM
kcw12's Avatar
kcw12
I beleive my windshield is leaking. right foot gets wet when driving. Anyways, i stuck my finger between the dash and windshield i could feel water. I searched the forums and couldn't find anything on that. And it only leaks when i am driving. How would you check and make sure that the windshield is leaking. Thanks
Old Oct 11, 2006 | 08:30 AM
kcw12's Avatar
kcw12
Ok check the windshield poored water down it. It is leaking. I think im gonna take it to a glass shop
Old Oct 11, 2006 | 08:37 AM
donnor's Avatar
donnor
stamp out wetness...
If you recently had your windshield replaced, it is quite likely that that is the source of your leak. If so, contact the shop that did the work. If not, a more likely place is one of the many points where 2 or more sheet metal panels come together & are spot welded then sealed with a caulk. This caulk, over time, can dry out, crack, and allow water (and yes, exhaust fumes) to enter the vehicle. Or, if a vehicle has panels that have been replaced as part of post accident repairs & the shop doing the work failed to properly reseal the areas, you may also experience leaks.
Finding the source can be difficult since the water can wick along a surface for some distance before and / or after entering the vehicle's interior. If you can narrow down the suspect area, seal up the cabin as tightly as possible with duct tape and pressurize it with the exhaust port of a large shop vacuum. Remember that many vehicles, Ford Trucks included, have one-way vents either in the doors or the back walls of the cabs that will need to be be blocked off for this method to work. Using a dropper or spray bottle, apply soapy water to the suspected leak spot and look for bubbles to appear.
It may sound easy, but unfortunately many times to get to the area you must partially or totally dismantle the interior.
dn.
Old Oct 11, 2006 | 08:51 AM
2tone73's Avatar
2tone73
Most Ford's I've seen have windshield rubbers that are split, instead of being joined. Where they are split they tend to leak in that area due to weather changes. Softening-Hardening back and forth. That is why there is such an issue with floor boards rusting out. Nasty flaw! I simply pumped some clear silicone in that area underneath the rubber. I have a 1973 f250 and the driverside floorboard is rusted through but not the pass. side hmmmmm, wonder why! You usually do not see it because it leaks down the rubber then behind the dash and underneath the carpet or rubber mat. Mine started leaking like yours recently. I hope this helps. Chad
Old Oct 11, 2006 | 09:03 AM
kcw12's Avatar
kcw12
Well i had a friend poor water down the windshield. And i could see where the water aws coming in at. It is coming from under the windshield..... Its on a 1990 f250. I can push the top of the dash down a little so i can see a little bit of the windshield and metal dash. When he poured water in there i watched it come out and run. So therefore i found my leak.
Old Oct 11, 2006 | 09:04 PM
kcw12's Avatar
kcw12
Problem fixed. The guy at the window shop bent some chrome and he did it for free.
