Glow plug controller
Old Oct 10, 2006 | 05:18 PM
deanj's Avatar
deanj
Having problems with my controller, messing up the alternator. Does anyone have a picture of the 94, that shows what wire to disconnect and connect thru a push switch to ground.
Old Oct 10, 2006 | 07:05 PM
dieself250's Avatar
dieself250
look in Dave Sponaugle's gallary he has a pic
Old Oct 10, 2006 | 10:19 PM
deanj's Avatar
deanj
He has the older g/p photo
Old Oct 11, 2006 | 10:40 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Remove the white wire and tape the end up.
Run a wire from the push button switch inside to the white wire terminal.
Ground the other terminal on the push button switch.
Turn the key to ON, push the button for 10 seconds, start the engine.
The ignition terminal on the relay is powered when the key is ON, so all you have to do is supply a ground to the white wire terminal to energise the relay.
Old Oct 13, 2006 | 06:34 AM
deanj's Avatar
deanj
Thanks Dave.
