2-Barrel vs. 4-Barrel Carb
Old Oct 10, 2006 | 04:45 PM
LARIAT 85's Avatar
LARIAT 85
My old Motorcraft carburetor for my 302 is on its last leg and needs to be rebuilt or replaced. What, if any, advantage does a 2-Barrel carb have over a 4-Barrel? I am asking this question because whenever I talk to mechanics around my area, they seem to try to get me to stay with a 2-Barrel. I mean, from my understanding, the only major work to do is change the intake and get a 4-Barrel carb to replace my 2-Barrel, right?
Old Oct 10, 2006 | 06:17 PM
Sycostang67's Avatar
Sycostang67
You can get better fuel economy with a 4bbl. A 2bbl carb just has 2 large holes to feed. A 4bbl carb has 4 smaller holes. If you can keep your foot out of the pedal, you are essentially only useing the 2 smaller holes on the front of the carb.
Old Oct 12, 2006 | 05:10 PM
Mil1ion's Avatar
Mil1ion
The 2v will provide more Torque at low Rpm. (better for yanking the truck out of a hole)
The 4v will provide more HP at high Rpm.
There is square bore and spread bore carbs intakes.
The square bore is like this
oo
oo
The spread bore is like this
oo
OO
The CFM rate on a 2v is usually around 480 -530 cfm
The CFM Rate on a 4v is usually 650 to 750 with the secondaries activated.
FTE has a Fuel Delivery forum for specific topics like this.
Old Oct 13, 2006 | 11:02 PM
RacinNdrummin's Avatar
RacinNdrummin
oo
oo
oo
OO
A 2bbl Wont give you more torque, Proper Carb sizing will. 2bbls are easier to manufacture, thats why they came stock. You will get more Torque and HP as well as fuel mileage with a Vacuum Secondary 4bbl carb set up, they were designed for that purpose.
Old Oct 13, 2006 | 11:24 PM
redlightning's Avatar
redlightning
I put one on my 83 F-100 with a stock 302.If I had it to do again I would just have rebuilt the 2 barrel.I had to come up with some linkage for the aod.I really didn,t think it was worth the hassel when I got it on,but I use it as just a truck not a hot rod.I very seldom got on it.
Old Oct 13, 2006 | 11:27 PM
85e150's Avatar
85e150
Rebuild the 2bbl for under $50 including beer or diet coke during the job.
You can get better mpg with a 4bbl but you won't.
If you go with a small (390 cfm) 4bbl, maybe you'll get better mpg.
If you research 4bbl manifolds, and go with a 600 cfm 4bbl, you can really wake up your motor, but it will cost you.
Old Oct 14, 2006 | 01:51 AM
Mil1ion's Avatar
Mil1ion
I think you mis-interpreted my comments.
Please Re-read the 1st two sentences.,
The Larger holes and fuel delivery on a 2 bbl carb will deliver more fuel to the engine than the 2 mains of a 4 bbl carb thus delvering more Torque.
This is one reason they put 2 bbl carbs on most trucks, More Low RPM Torque from idle to top of power band.
Vacuum secondaries don't come on until almost full throttle.
Old Oct 14, 2006 | 10:06 PM
LARIAT 85's Avatar
LARIAT 85
Thanks guys! This is exactly what I was looking for. Basically I was wondering, why, if the 4-barrel is so much better than the two barrel, did so many Ford trucks come equipped with a 2 barrel carburetor. I knew there had to be a good enough reason why the engineers did it this way.
Old Oct 14, 2006 | 11:52 PM
85e150's Avatar
85e150
I don't know that it is "The" reason, but the fact is that the 2bbl will pass enough air to meet the demands of most of the truck engines. Low revs don't need huge carbs.
Old Oct 15, 2006 | 11:43 AM
jinserra's Avatar
jinserra
I dont know, I put a 600 cfm edelbrock on my 351w and the truck is running alot smoother and I havent driven the truck to work lately(60 miles one way) to check gas mileage but local running around is hovering around 11.5 - 12mpg
Old Oct 16, 2006 | 08:20 AM
Franklin2's Avatar
Franklin2
Most people get a boost in performance from a 4bbl over the stock 2bbl because the 4bbl is usually a "universal fit" and is jetted richer than the stock 2bbl.
In the original engine set-up, there is a lot of emissions stuff, and the engine has a delicate balance of tuning with timing, and jetting of the original carb along with the egr and other components. Disconnect one thing, or change one thing,(even the exhaust system) and you mess up the tune of the engine. And the engineers did have their hands tied a little bit too, since they have government emissions standards to keep.
Buy a aftermarket 4bbl(or even an aftermarket 2bbl) and it will be jetted a little on the rich side, which will cover up the many sins from taking emission devices off, putting headers on, advancing the timing, etc. So it will naturally tend to run better in these situations.
jonny.redneck
Apr 23, 2014 04:43 PM
JRB65
23
Dec 12, 2012 10:27 AM
ericford1984
Dec 5, 2011 08:47 PM
79custom4x4
Jan 13, 2009 02:33 PM
truckman79
37
Jan 15, 2004 04:12 AM
