Help, Anyone
Old Jul 21, 1999 | 11:44 AM
Joel Mullis
Guest
Posts: n/a
Help, Anyone
I've inherited a crate engine (351M). The engine is going in a 1966 F-100. I have an invoice with the folowing on it: lift (288), valve lift (461), duration (288) and the name of the cam (ELGIN). Can someone tell me what this means and whether this is good or bad? Also I need to know if the pulleys on a 351C and a 351M are the same. If are not tired of questions from a novice scroll down and look at the other posting I have about the 351M. The title of the posting is 351M PULLLEYS, OIL PAN, AND HEADS.
Thanks
Old Jul 25, 1999 | 05:26 AM
Michael Strawn
Guest
Posts: n/a
Help, Anyone
The number 288 is lift at the cam lobe, 461 is lift at the valve with a 1.6 ratio rocker. (461/288=1.6). The 288 duration is the advertised duration which would be measured from open to close of the valves.
Old Jul 31, 1999 | 08:37 AM
Fordman's Avatar
Fordman
Help, Anyone
