I have a 1963 Ford F-100 Unibody and due to the steering box I won't be able to fit a 460 from a ranchero into the truck unless i do something to the exhaust. Should I just keep the original 292 in it or try to reroute the exhaust on the 460....
I would definately go with the 460 and then try to reroute the exhaust. If you cant do it most likely a custom exhaust shop will be able to do what you need. Good luck
