MSD ready to run distributer
Old Oct 10, 2006 | 10:34 AM
fjord250's Avatar
fjord250
Any body have this set up.. Doing a 400 build and went with the "Ready to Run" unit. It does away with stock module and does not need any other ignition parts. Everything is internal, hook up three wires and your done so the directions say.... Just wondering if anyone has had any experience with this rig..
Old Oct 17, 2006 | 10:44 PM
PerfDistIgnition's Avatar
PerfDistIgnition
FTE Sponsor
If you decide to go with a new distributor, see our custom curved D.U.I.-Davis Unified Ignition and Duraspark distributors at:
http://www.performancedistributors.com/forddui.htm
__________________
FTE Sponsor
Performance Distributors
www.PerformanceDistributors.com
Old Oct 23, 2006 | 11:55 AM
Tinman55's Avatar
Tinman55
Thumbs up
Yeah, that's all you do. Just make sure you've got a good coil and it'll rock. I've got one in my Cleveland and I noticed a huge improvement in starting and upper RPM perf.
Old Oct 23, 2006 | 11:27 PM
roger dowty's Avatar
roger dowty
[QUOTE=PerfDistIgnition]If you decide to go with a new distributor, see our custom curved D.U.I.-Davis Unified Ignition and Duraspark distributors at:
http://www.performancedistributors.com/forddui.htm[/QUOTE]
looked at your site and you claim the dui is the only hei system for ford. Wondering what you mean as i have a pro-comp sitting on my kids wheezer and a no-name backup for my 400. TMI sells 2 types of hei distributors for the 400. I might go with your durasprk replacement- the retard at startup seems to be important to the wheezer-
do you have the wiring harness for a 77 duraspark system?
Old Oct 24, 2006 | 01:12 PM
PerfDistIgnition
FTE Sponsor
1) I know we were the first to make it-My Dad invented it. Ours is made in the USA!
2) The retard at start-up should not be important IF you have a custom calibrated advance curve, which makes for easy starts and better power.
3) See our Dyna-Module, which we offer to go with our Duraspark at:
AND scroll down to the Duraspark section. We provide a color coded wiring schematic to go with it.
__________________
FTE Sponsor
