1979 F150 Weight
Old Oct 9, 2006 | 09:38 PM
Dustin1690's Avatar
Dustin1690
1979 F150 Weight
Hey everybody i got a question i would like to know what would be the weight of a 1979 F150 Ranger XLT Reg Cab long box its got a 460 but aint in the truck engines gone most likely has stock rims with stock tires everything else is there except the engine has an a auto tranny im guessing a C6? i think this truck is a trailer special but the truck is pretty far away from me so i dont know i would like to know what would be the weight of it without the engine in it or with it in dont matter and how much would the 460 weight Thanks for the help id appreciate if the weight numbers where as accurate as possible... thanks again
Old Oct 9, 2006 | 09:43 PM
brentleedragon's Avatar
brentleedragon
i believe it is 4000-5000 lbs
Old Oct 9, 2006 | 11:25 PM
79Indy's Avatar
79Indy
I have a '79 F150 regular cab long bed. The actual measured weight of the empty truck is 4,180lbs. Mine has a 302/C6 combo and I've been told a 302 weighs 475lbs. Somebody correct me on the engine weight if that is wrong. That should get you in the ballpark.
Old Oct 10, 2006 | 08:12 PM
xlt ranger lover's Avatar
xlt ranger lover
my truck is a 2wd long bed, 351m and c6, it weighs 4,300.
Old Oct 10, 2006 | 08:19 PM
bigblackbeast's Avatar
bigblackbeast
my 79 f150 4wd 460 4sp with 35" tires weighed 5300lbs at the landfill when empty with all the regular gear in the truck
Old Oct 10, 2006 | 09:40 PM
Dustin1690's Avatar
Dustin1690
So even without the 460 installed it will still weigh around 4000-5000 lbs and btw thanks for the help
LxMan1's Avatar
LxMan1
My 77 std cab long bed 2wd with a 460/C6 weighs 4480lbs. So without the 460, I would guess about 3900lbs.
Old Oct 10, 2006 | 10:04 PM
Dustin1690's Avatar
Dustin1690
Alrighty thanks very much Lxman appreciate it..
Old Oct 10, 2006 | 11:35 PM
brentleedragon
my 302 f150 weighs 4000 roughly whenever i go to the dump scales but it think they mess with it because i weigh 190 and when i get off the scales it goes down about 250-300 lbs lol so yea
Old Oct 11, 2006 | 10:31 PM
Dustin1690's Avatar
Dustin1690
Weird how that works eh well thanks again for the help kind of confusing and ironic that these are called 1/2 tons but are actually more than half a ton just like my dad said they where actually made out of something back then.....
Old Oct 12, 2006 | 12:29 AM
Mil1ion's Avatar
Mil1ion
I think the 460 weighed 580 lbs.
Old Oct 12, 2006 | 07:09 PM
Dustin_86's Avatar
Dustin_86
Man! I never realized they were that light A new f150 has more metal I guess
Old Oct 12, 2006 | 09:24 PM
Dustin1690's Avatar
Dustin1690
Lol that really sure aint light to me a old reg cab long box weighs 4000 to 5000 lbs depends on options of course but they weigh probably as much as a newer F150 supercab or crew older ones
Old Oct 12, 2006 | 09:45 PM
brentleedragon
all the new trucks weigh more really, because they are "loaded" look at all the things that come in newer trucks and look how simple ours are
and dont they use heavier frames now a days?
Old Oct 12, 2006 | 10:43 PM
MBBFord's Avatar
MBBFord
The new F-150s weight about 3 tons, which is far from light.
They don't have more metal, but the frame is alot bigger(it's fully boxed in), compaired to the c channel frame on our trucks. The rear axle in the 1/2 ton in 9 3/4" and in ours it's 9", and all the options they have add up.
The 97-03 models didn't rearly weight 3 tons though, just the 04-06s really packed on the weight.
BPCheeta
All Things Towing
Jun 9, 2017 12:59 PM
AKHunter93
27
May 9, 2016 04:42 AM
Highboy74
Jan 20, 2011 02:23 PM
oldjag
New Member Introductions
Jan 23, 2007 09:25 PM
oldcar29
Jan 27, 2006 11:31 AM
