Can anyone point me to a place where I could find a recommended maintenance schedule for my 03 X? I've looked through the owner's manual and didn't find one. Thanks.
It says to change automatic transmission fluid every 30,000 miles and then at 150,000 miles it says change automatic transmission/transaxle fluid and filter, implying that the same fluid goes through the transfer case as the transmission.
Farther down it says change transfer case fluid at 150,000 miles.
Have no idea about the requirements for your V10, but tranny and transfer case are two seperate systems. I tend to do the tranny a few thousand early as ATF fluid is cheap (I do a flush and not just a drain & fill).
I did my transfer case at 50,000 miles and my front and rear diff's at 75,000 miles... but my rear-end uses synthetic gear lube right from Ford on my 2003 Diesel... so not sure if your V10 is the same or not?
