Green or Orange antifreeze?
What ever you do don't mix green and orange. They're not compatible and can turn acidic and eat your cooling system.
Also you can check for galvanic corosion by taking a volt meter and ground it on the neg end and hang the positive end in the coolant. If you get voltage then you've got galvanic corrosion and it's eating the softer metal. They even sell zinc anodes that are on the radiator cap that will act as the sacraficial metal. I say fix the problem, but I guess it's good insurance.
I was trying to figure a way of putting a zinc in my cooling system but had not come up with a slick way of doing it. ---The radiator cap anode, where have you seen that for sale?---- Is the zinc actually on the bottom of the cap so that it is in contact with the coolant?
The zinc is a double good idea because if you see that the zinc is deteriorating you know that your system needs attention. And it protects the system because the zinc is the "least nobel" metal in the system so it is the first to be attacked if you have a galvanic problem.
I did that with the voltmeter and got .20 volts,does that count or what? It has Prestone green with regular tap water in her,Been like that for years too.
She does run rough untill it warms up and then it runs a little better. With that much voltage,how bad do you think my cooling system is messed up? Any damage to the block perhaps?
I'll check the straps you mentioned in about a half hour,I checked my haynes manual but couldn't find a place that told me where all the grounds are. If they're in there,what do I look under?
Thanks Bdox.
Thanks Bdox.
Speaking of the intake,I looked for them ground straps,The engine to firewall one and only one I seen was from my intake manifolds. Is that the one you was talking about? And I grounded the multimeter to the battery and touched the rad. cap on the radiator,I still got .14 volts. I went for a stretch and just touched the water on the brim with the cap off and still got .4 or so. Is it possible my meter is to acurate or off? Its a craftsman digital that reads almost everything.
