I am currently running a diablo predator on my 2000 excursion 7.3 PSD. What options do I have that I can stack safely with the predator that will not cause any harm to my engine or trans? Any suggestions would be gratly appreciated.
I've got a predator on my stroker and I love it, will be going to a flip chip soon though for the ease of tune change. Only complaint is the 100 hp setting isn't made for 6-speeds.
About the only thing you can stack with it is a Banks 6-gun. Of course, you can make that pretty cheap too. It's just a glorified 10K-18K mod.
I had a Predator stacked with a 6-gun quite a while ago. The 6-gun helped a little, but didn't give much of a boost in power, but it did give some.
However, with the switch to a DP tuner, Jody's chip gave more power than the 6-gun did on it's highest level stacked with the Predator set on its max setting. Plus, it burns cleaner and has lower EGTs. Just my observations.
