guages ordered, have ?
Old Oct 7, 2006 | 10:52 PM
pullinair's Avatar
pullinair
Smile guages ordered, have ?
Isspro kit ordered
what temps am i looking to be at pre turbo?
I have a six speed manual, How do i get my wires/ tubes through the fire wall since the master cylinder is in the way?
and what tips and tricks are out there for usinf the clamp pyro -pre turbo
thanks
Old Oct 8, 2006 | 05:58 AM
jetdoc's Avatar
jetdoc
Temperatures can vary quite a bit. I'll see 450-475 going down the road at 55MPH. After I glued my intercooler boots I saw a dramatic increase in boost and lower EGT as well. I drilled a hole below the clutch master cyl. I'll take a picture later on if you want. I didnt use the clamp pre turbo. Just drilled a hole in the manifold! I think it would be hard to get a drill in there to put a clamp in the up pipe.
Duncan
Old Oct 8, 2006 | 07:00 AM
pullinair's Avatar
pullinair
thank you for the reply
Old Oct 8, 2006 | 09:33 AM
pbr man's Avatar
pbr man
I ran my wires through the rubber boot around the steering column. Just poked a small hole and pushed the wires through and it sealed itself around the wires.
Old Oct 8, 2006 | 11:14 AM
Kwikkordead's Avatar
Kwikkordead
Drilling the exhaust manifold is easier than you might think. It's best to drill a very small pilot hole, using plenty of penetrating oil as a lubricant and then drill out the final size for tapping the threads.
IMO the threaded connection is the best because there is NO WAY for any leaks to develope. The hole and clamp method in the up pipe, seems to me, would allow a bit of exhaust pressure out around the probe.
Old Oct 8, 2006 | 11:47 AM
TwelveAlpha's Avatar
TwelveAlpha
Navistar would tell you that you don't want to exceed 1200 degrees for EGTs.
