2001 f-150 5.4L supercrew. When turning ignition sw. to on pos. should I be able to hear the fuel pump? The engine turns over like normal but won't fire. Also Is there a fuse for the fuel pump?
-Thanks a million,
M.C.
They are pretty quiet, at least mine is.
You can check for pressure at the schrader valve on the fuel rail.
There may be a fuse in the power distribution box under the hood.
