Was wondering if anyone could help me figure out what my ratio is 3.73 gears, 35x12.50x17 on 05 f-250. Keep hearing that I should have more power and better fuel mileage? Any idea of what my ratio would be with these tires and how much my speedo is off? Thanks
Going from a 31.5" tire to a 35" tire w/3.73 gears would give you a new effective ratio of 3.36.
Examples of MPH changes:Speedometer vs. Actual Speed
45=50
55=61.1
65=72.2
75=83.3
More power. . .No. The truck may actually feel a bit more sluggish off of the line with the new effective gear ratio and bigger/heavier tires. More MPG. . .Maybe. But only a very slight positive change, and probably not worth the loss in low-end grunt.
To get back to close to an equivalent gear ratio you would need to put in at least 4.10's (which would still be below equivalent) or 4.30's (which would be above equivalent).
EnviroCon, You're info is greatly appreciated. I guess my post wasn't worded correctly, I meant that the truck was under powered because of the bigger tires not that I should have more power. Anyway thanks for the input.
Glad I could help. But I would highly recommend that you get the speedo corrected. There are are several systems that use that info to decide how to operate and without the correct info they may be causing even more of a feel of power loss, among other problems. Here's an article from Ford Doctor's site that talks about it: http://www.forddoctorsdts.com/articles/article-05-21.php
There are 3 ways to recalibrate the speedo:
1. A tuner that has the ability to change the tire size in the PCM. I'm not sure which ones, since I don't use a tuner.
2. A friendly dealer that doesn't mind doing it. Usually they'll just charge you the hourly shop rate.
3. A Superlift TruSpeed speedometer recalibrator. This is what I use on my dually. I prefer this one because it allows you to adjust the signal yourself with a GPS, so you can usually get the speedo closer to your actual speed than the PCM re-programming. And the install is not that difficult.
I have the similar situation I keep hearing people talk about. Specifically, 31 inch tires and I want to install 35". I have the 6.0 diesel and wondered if changing the gear takes care of the speedo recalc, or does the speedo still need a change? I'm thinking since I tow, I should change the gears to 4:30 to be closer, or above what I have now. Has anyone towed a trailer WITHOUT changing the gears? Is the power loss substantial?
No, you'll still have to tell the PCM what tire size you have, or trick it with a TruSpeed.
It will depend on the gears you have now. I tow my toys (6k pounds max.) with mine all the time and it works just fine. The truck has the original 4.10's still in it. With the 35" tires I now have an effective gear ratio of about 3.73ish. I noticed a slight change in performance going uphill, but that's about it. The 6.0 has enough torque that it tends to compensate well.
What is the cost and time involved to DIY on a gear change out? Given they are sending out 3.73's w/ factory tires @ 20" (like mine) you start w/ incorrect gears from the get go.
Dealer doesn't seem to get it and doesn't order an upgrade to the lower 4.10's w/ the 20" tires.
Normally I would say "what the heck, give it a shot", but not with gears. Unless you have someone helping you that has done gears before, I wouldn't recommend doing them yourself. Setting up gears is tricky. It requires a bunch of special tools, or some tried and true homegrown methods with a good amount of experience when things don't go according to plan. Which they almost never do. Not to mention that gears need to be set-up with an accuracy in the thousandths of an inch and don't tolerate errors and tend to lock-up or explode inside the case if done wrong. Any $ you might save on labor costs would quickly be eaten up by having to buy new parts.
I agree with the other posts that setting the gears needs a special, qualified touch. However, can't the DIY guy pull the axles and separate the pumpkin and take it to the guy with the right touch in order to save a little money and time.
Maybe, depends on the guy doing the work. And if you are going to pull the axles and take the complete rear axle housing out of your PSD (axle housing is 1 piece) then take it to your local R&P shop, then re-install the axle assembly in your SD, is the time and energy worth it to you? And if it is a 4x4 you have got to do both axles at the same time. Defenitely a personal choice and i would want a big cost savings from my local R&P mechanic to justify this process.
