Oil & Lubrication
Front Differential Lube?
Old Oct 7, 2006 | 01:55 PM
PW01's Avatar
PW01
I have a 2001 Ranger 4x4, and would like to change the front diff lube. Given the location of the cover, I will have to use the "pump out" method. The manual call for 3.6 pints of 80w-90. I would like to use a fully synthetic lube, preferably Mobil 1, but I can only find 75w-90. Would it be advisable, or cause problem, to use this weight? Thanks!
Old Oct 7, 2006 | 03:11 PM
Hootbro's Avatar
Hootbro
Nothing is going to exploded using the 75W-90 in place of the 80W-90. I have done it on numerous different applications over the years with no ill effects.
Hootbro
Old Oct 7, 2006 | 06:01 PM
aurgathor's Avatar
aurgathor
It should be good enough. If it were the rear axle, I'd argue that 75w-140 would be a better choice, but it's the front axle, and they're often filled with slightly lighter oil.
Old Oct 7, 2006 | 08:04 PM
jfsully's Avatar
jfsully
80W-90 Synthetic Gear Lube
Amsoil makes a 80W-90 synthetic gear lube.
Hensley1027
Michigan Chapter
Sep 23, 2010 01:17 PM
Gage2502
Apr 21, 2008 10:43 AM
hornet41
Feb 18, 2007 01:09 PM
john111222
Oil & Lubrication
Sep 5, 2004 06:17 AM
