Mystery Transmission problem
First time poster.
My uncle has a 2000 Ford F-350 V-8 Power Stroke Diesel Camper and 4X4 Conversion Van. We've been all over the country in this camper and it has done very well overall. Recently, though, we've had some transmission problems. Here's a rundown.
Initial problem: transmission began shifting gears too often in all gears and then would not engage gears. Speedometer quit working. Diagnosis of faulty "VSS" which was replaced June of '06.
After about 90 miles of driving, the problem returned and the transmission range sensor was replaced August '06.
Present problem: transmission continues to shift gears too often after 90 to 200 miles of driving. After cooling for several hours it works properly again for another length of time. It does not slip nor does the speedometer stop working. At last incident was taken out of overdrive for several miles and when returned to overdrive the problem did not reappear through rest of trip (about 50 miles). The cruise control seems to become unsteady about the time the problem appears. Two transmission specialists say the actual gears in the transmission are working perfectly and that it is some sort of electrical/electronic problem.
We're stumped. Any suggestions?
