Annoying Squeal When Turning
Old Oct 6, 2006 | 11:11 PM
03eddie's Avatar
03eddie
It has actually gotten worse... When i turn right no matter if it is a sharp turn or not.. I get a squeal.. Best way to describe it is as if you are in a parking garage and going fast on a turn and you get ur tire to squeal.. Only it is not the tire.. It does it at fast or slow speed... Any Ideas.. I dont think it is major.. Just annoying.
Old Oct 6, 2006 | 11:18 PM
Freak4Ford's Avatar
Freak4Ford
Have you checked your tire pressure? How old are the tires? Are they worn? Do you have abnormal wear on your tires? How about your alignment? Sorry for all the questions but they needed to be asked.
Old Oct 6, 2006 | 11:31 PM
03eddie's Avatar
03eddie
Tires are great... No abnormal wear.. Pressure is exactly right... Alignment is great... I can tell it is not from the tire.. I had a grand cherokee do it before.. turned out one of the power steering lines to the pump was not on correctly.. Came that way from the factory..
Old Oct 7, 2006 | 09:10 AM
artfuldodger's Avatar
artfuldodger
A squeal when turning is commonly a problem in the power steering unit.
Old Oct 7, 2006 | 11:36 AM
03eddie's Avatar
03eddie
So is that something major or just an annoyance?
