Starter problems??
Old Oct 6, 2006 | 06:45 PM
dankoos's Avatar
dankoos
Starter problems??
Just bought a 1992 F-150. Started just fine when I test drove and when I went to pick it up..day after I brought it home..won't start. Makes loud clicking noise when I turn the key. Tried using a wire to skip the solenoid/relay there by the fender...got same clicking noise. Battery is supposedly new..looks new..but when I tried the wire/solenoid thing..the battery hissed a bit near the negative connection and I even saw a small wisp of "smoke". Battery is being tested now..if that is not the problem..could it be the starter? Have seen some posts where someone mentions clicking and always seems to be the issue. Please help! I am not mechanically inclined when it comes to cars..but I can follow instructions!!! Thanks!
Old Oct 6, 2006 | 06:53 PM
andym's Avatar
andym
You've ruled out a bunch of things, so it's either the starter, the battery, or the battery cables themselves. Good news is that the battery and the starter can be tested, so if they're OK, you can just buy new battery cables.
Old Oct 6, 2006 | 07:58 PM
Josh88Ford's Avatar
Josh88Ford
when you turn the key forward, or back, are you getting the radio, lights etc?
I am thinking if the truck started fine for test driving, and didnt miss or wind, it wouldn't be the starter, but get the battery and starter tested both, jsut for future reference. Its good to just replace your battery cables and terminals anyway. Cheap, and well worth it.
Old Oct 6, 2006 | 08:13 PM
quicklook2's Avatar
quicklook2
check spade connector on starter.
Old Oct 7, 2006 | 05:49 AM
cbslayer's Avatar
cbslayer
almost always i find it to be the terminals and the after market ones usually are not any better i just buy a new cable they are not that expensive and if it saves me from being stuck well worth it
Old Oct 7, 2006 | 06:08 AM
headcustodian's Avatar
headcustodian
DITTO, cbslayer
Old Oct 7, 2006 | 07:22 AM
dankoos's Avatar
dankoos
Well, they told me my battery was dead..which was weird since lights and everything would work..so I bought a new one...still won't start. No clicking when I turn the key now...but if I use the wire across the relay/solenoid thing there off the fender it will click. Still get that "hissing" sound from the negative battery terminal...thinking maybe it is the cable??
Old Oct 7, 2006 | 09:28 AM
puck1263's Avatar
puck1263
sounds like cable replacement. The resistance in the cable is A. straining your battery, B. not letting enough amperage get to your starter. I wouldn't try it any more till you do that to avoid damaging your new battery.
Old Oct 13, 2006 | 12:21 PM
dankoos's Avatar
dankoos
You were correct! The cables were corroded and just needed cleaned. In-laws said I should get them replaced at some point, but cleaning them got it running...happy it was that simple.
Old Oct 18, 2006 | 09:40 PM
dan1101's Avatar
dan1101
You'll be back to cleaning them again, the F-150 is real picky about having clean battery connections. My 95 has did that to me at least 3 times. I had a good run last time of 6 months or more, and even though the battery terminals on the ends of my cables were clean, where the wires clamped into the terminals was not. A little wire brushing and it started up again fine.
Also, there is a negative wire attached to the starter with a simple spade connector. Down there in all the water and salt and what-not. That's been a problem for me once or twice. I got a NAPA replacement starter and it has a better redesigned connection for the negative wire.
