Rear Diff fluid
Old Oct 6, 2006 | 08:57 AM
powerstrokin007's Avatar
powerstrokin007
Rear Diff fluid
Since I have about 50,000 miles on my truck i'm going to change the rear diff fluid. Does anyone recommed any particular fluid? I always used some off the wall 90w. What about a limited slip additive? Anything good?
Old Oct 6, 2006 | 09:28 AM
Kwikkordead's Avatar
Kwikkordead
For my open diff I use Redline Shock Proof Heavy gear oil. I used it to quiet down a clunky rear end in my '91 F-250. It would give a heavy knock sound at the start of every accelloration from a stop light. After changing the rear end oil for the Shockproof it never knocked again.
http://www.redlineoil.com/products_g...6&categoryID=6
There is a lot of other choices from them as well.
Old Oct 6, 2006 | 09:33 AM
RAMPAGE_F350's Avatar
RAMPAGE_F350
I use Royal Purple 75W140 gear oil in the rear diff and it already has the limited slip additive in it.
Old Oct 6, 2006 | 09:58 AM
herman2001's Avatar
herman2001
I changed mine last month when the rear diff cover rotted off... I just put in delo 75w90 and no problems so far
Old Oct 6, 2006 | 10:33 AM
KrenzyRyan's Avatar
KrenzyRyan
im using 75w140 mobil
Old Oct 6, 2006 | 12:08 PM
Fat Diesel's Avatar
Fat Diesel
If you have a limited slip diff, you want to use 75w140 SYNTHETIC. If you buy Red Line, don't buy the "LS" stuff. Some trucks require the friction modifier with some oils, some don't. Friction Modifier is $5 for a small bottle at Ford.
Old Oct 6, 2006 | 07:29 PM
magnum300's Avatar
magnum300
I put Royal Purple in mine
Old Oct 6, 2006 | 09:49 PM
2002f2507.3LPS's Avatar
2002f2507.3LPS
how do u know if u have the limited slip diff?
Old Oct 7, 2006 | 01:12 PM
powerstrokin007
Hadn't check yet. Just another question to ask if I do.
Old Oct 7, 2006 | 06:01 PM
magnum300's Avatar
magnum300
Go to the super duty forum and the read first 99-04 FAQ's, vin and tag decoder some people will have that code on the door piller sticker, for mine and others do not have this so you have to look at the tag on the differential cover if it has an L in it you have limited slip, or find a gravel road and punch it if you leave 2 burnout marks you have limited slip
Could someomne chime in on why some have the code on door sticker and others do not
Old Oct 7, 2006 | 06:21 PM
2002f2507.3LPS
well one tag said this on it. ( S 409 H ) below that on the same tag it said this ( L 73 10 5 1K 17 )
the other tag just said ( 75 w 140 synth oil only. ) wich im sure is just the oil to refill the rear end with.
Old Oct 7, 2006 | 08:14 PM
powerstrokin007
Useful information. On my sticker it has D1 and when you look it up it's a 3.73 limited slip. Thanks.
Old Oct 7, 2006 | 08:52 PM
magnum300's Avatar
magnum300
You have a 3.73 limited slip
Old Oct 7, 2006 | 09:00 PM
Uzumati's Avatar
Uzumati
Unless you have a different rear end the 75W90 is for the front and the 75W140 is for the rear
Old Oct 8, 2006 | 01:49 PM
powerstrokin007
Now with that fluid, what outside temp is it good for? Just wondering if it will hold up to the temp in Anchorage. Last year it got to -25 degrees outside.
