no start problem
Old Oct 5, 2006 | 11:32 PM
300inline6's Avatar
300inline6
no start problem
I just got a '79 F-250 with a 460. I can't get the truck to start. I don't have spark at the distributor and with just the key on i have around 6 volt at the coil. Is this right? If not what should be the first thing i should check.
Old Oct 6, 2006 | 01:04 AM
Mil1ion's Avatar
Mil1ion
The ignition system needs 8 volts to operate.
Do you have a multi-meter (V.O.Meter ) ?
We need to test some circuits.
Battery condition ?
You need a fully-charged battery for test purposes .
Need to:
Measure voltage at coil when key in Start position
Voltage at coil with key in RUN position.
Get back with those figures.
Old Oct 7, 2006 | 01:18 PM
300inline6's Avatar
300inline6
The voltage at the coil when the key is in the start position is 7.1 volts and when cranking over is 9.5 volts.
Old Oct 11, 2006 | 01:58 AM
Mil1ion's Avatar
Mil1ion
It's not high enough.
Check your battery and do a coil resistance test.
