The mylarized bubble wrap has gotten poor reviews in longer term use on other sites, thermal performance is not that good in headliner service. The roofing products are Peel N Stick and an unnamed product by the same company that is without the foil. They don't work under roofs for long, the adhesive just isn't made for that. Works super on floors but again its adhesive limits it to "gravity assisted" applications.
Here is an excellent site with tests of Dynamat competitors:
I had used the mylar bubble wrap insulation in a previous project and it held up very well. I installed it in my truck a year ago this past summer using 3M adhesive. It was still in place when I installed the headliner a week ago so I think the type of adhesive used has a lot to do with it staying in place. On my firewall, in addition to adhesive, I used machine screws through the holes where the original firewall cover was attached and flat washers on the inside. That will never come loose unless the screws are removed.
Wow, this thread has taken on a life of it's own. I appreciate the advise I've read so far and will probably drive without a headliner for awhile until I figure out which direction I'm going. I have some insultator left over from the floor which is the kind which has foil on one side and will probably put that between the roof and headliner when I get to the final installation.
Step 3: Someday, install your headliner, interior and insulation.
Note: The Rod Doors headliner comes with a very nice piece of insulation included. Also, the holes where the bolts for the seat belts can be cut later. You can make a diagram to pinpoint the location with a piece of cardboard set against the rear window on one side and the frame of the door on the other.
Well, I can attest to the fact the this group will gladly tell you where to go and exactly how to ge there............(well, at least they are always telling me where to go)
Carlene, for the most part the year of the truck has little to do with how and what to use to solve a problem, so feel free to come here as often as you'd like for help and advice. We just won't be able to help you much with cross springs, torque tube drive, wishbones and such earlier pre war technology.
Seawullf Are you trying to stay orginal. If not look at a mid 80's( or later) seat with the seat belts in the seat. This gives you the shoulder and lap belt no holes. This is what I will be doing with mine. Just make sure you give yourself a really good anchor job on your seat.
Max E
Seawullf Are you trying to stay orginal. If not look at a mid 80's( or later) seat with the seat belts in the seat. This gives you the shoulder and lap belt no holes. This is what I will be doing with mine. Just make sure you give yourself a really good anchor job on your seat. Also you don't have to pay for a seat covering!!!
Max E
We used RAAMmat in our 60, it worked great! We did the entire inside (including the entire inside of the doors), it looked like a miro-wave oven. Much quieter ride and the stereo sounds great. Total cost for the dampener and sound proofing was about $400.
Thanks for the imput Walston. It looks like a good product for the money and its not like the truck's gonna be sitting out baking in this Florida sun all the time. Its always nice to here from someone that has actually used a product you just purchased.
Bobby, I visit this forum enough to know that "you are not kidding". In all seriousness, I lurk around here for the entertainment value. Good thing you guys haven't figured out how to charge admission.
I just receive my RAAMmat today and the backing seems a bit difficult to peel off. Have to use a razor to get the black stuff off the backing. Is this normal? Do I just need to go at it with a lot of patience??
