1978 - 1996 Big Bronco
tranny problem
Old Oct 5, 2006 | 06:40 PM
92custom302's Avatar
92custom302
tranny problem
At first i thought my trans wasnt going into gear because i would push the gas and nothing would happen, but i realized today that if i revved the engine real high it would move, slowly but it goes. Any thoughts about this?
Old Oct 5, 2006 | 06:50 PM
LedheadELH's Avatar
LedheadELH
if it's an automatic, you could be low on fluid....check that, and if it's got enough fluid then let me know, automatics are pretty simple.....usually
oh and when you were revving the hell out of it, you were probly slipping the clutches, because there isn't enough tranny fluid to put enough pressure on clutch packs, and servos for the bands, just to let you know, but I wouldn't worry bout it, as long as you didn't do it much!
Old Oct 5, 2006 | 08:20 PM
92custom302
It is an automatic, i didnt rev it too much i try not to act like too much of an idiot. Im going to check the fluid tommorow after i get off work and ill get back to you, thanks.
Old Oct 5, 2006 | 08:42 PM
dwoodler's Avatar
dwoodler
Sounds like that's the problem to me too. I've had it happen a few times but the next question is ... Where's the leak?
Old Oct 5, 2006 | 09:45 PM
greystreak92's Avatar
greystreak92
A 92 is gonna have an E4OD in it. Pull the codes too. there may be a simple answer to the problem there as well.
Old Oct 6, 2006 | 09:03 AM
Kemicalburns's Avatar
Kemicalburns
is your transfercase in neutral?
Old Oct 6, 2006 | 06:14 PM
92custom302
well it was a little low sow i put some fluid in it and its still the same. Id say the transfer case is in neutral its push button and its off.
Old Oct 7, 2006 | 03:02 PM
greystreak92
The electronically shifted case has no neutral position
