Tranny Lines
Old Oct 5, 2006 | 01:12 PM
Kazco's Avatar
Kazco
Tranny Lines
We are in the process of replacing the 240 6cyl with a 302 and c4 tranny. We are gathering everything we can before we start.
We have a question, does anyone know where we can get the transmission cooling lines that go to the radiator? We have checked quite a few catalogs and it seems no one carries them.
Thanks,
Mike
Old Oct 5, 2006 | 01:38 PM
bertha66's Avatar
bertha66
When my son and I replaced his we use strait 5/16" brake lines and bent them with a tube bender. Used 4' of 5/16" brake line for each one.
Old Oct 5, 2006 | 01:52 PM
Kazco's Avatar
Kazco
Bertha66,
What type of flare did you put on the ends? Is flaring the tubing hard to do?
Thanks,
Old Oct 5, 2006 | 02:47 PM
BlueovalFE's Avatar
BlueovalFE
Originally Posted by Kazco
Bertha66,
Thanks,
Nope, when you get a tubing bender, sometimes they come with a flair tool. Just make sure your flair is even all around. I used one to make a fuel line.
Old Oct 5, 2006 | 02:49 PM
bertha66's Avatar
bertha66
I got the lines from a parts house here, they were premade strait brake/fuel lines with the fittings alreaty on them.
Old Oct 5, 2006 | 03:29 PM
jowilker's Avatar
jowilker
Mike, Like the others, I bought two straight lines with ends from Advance Auto and bent them myself. I do think I had to step up the fitting size at the radiator.
good luck
John
Old Oct 6, 2006 | 08:13 AM
Kazco's Avatar
Kazco
Thanks to all, it doesn't sound to bad to do now. I think we will go with the tubing with the ends already on it.
Thanks again,
Mike
