1978 - 1996 Big Bronco
??fuel pump??
Old Oct 5, 2006 | 07:52 AM
Okcdiscgolfer's Avatar
Okcdiscgolfer
??fuel pump??
OK...... this is what I can tell you about my little problem.
89 Bronco fuel injected 302
Yesterday I turned my truck off and the rail mounted fuel pump continued to run. After disconnecting the battery for over 10 minutes it started to work normally. It would run constant after disconecting battery for a few seconds.
About 1 hour ago I was pulling into the bank and the truck stalled out. It would appear that I am having a fuel delivery issue. Power is going to the pump when key is on.
Anyone ever hear of a pump running constant?...... Is it simply the fuel pump or would you belive there is another issue?
I am waiting on the tow truck to call me so I can get it home.... Any input would be appriciated.
Dave
Old Oct 5, 2006 | 08:08 AM
Okcdiscgolfer
Could it maybe be a cloged filter?
Would it be a good idea to just replace it after it was wanting to run constant yesterday With the key off and out of the truck?
Parts guy said he showed a relay for the pump.... should I look at this first? If so how would I test?
Thanks
Dave
Old Oct 5, 2006 | 10:52 AM
Kemicalburns's Avatar
Kemicalburns
sounds like your fuel pressure regulator or a stuck open injector. Pull the vacum line off of the FPR if gas is present then that is your problem. also pull the oil dipstick out and smell if for fuel, if present you might have a bad injector if the first thing i mentioned isnt present.
Old Oct 5, 2006 | 02:36 PM
mako171's Avatar
mako171
Sounds like the fuel pump relay to me. I have had one stick, as the contacts become worn. By the same token, it will stay off, when it's suppose to be on, too. The relays are cheap, less than $10, and easy to replace. Try it.
Old Oct 6, 2006 | 07:56 AM
Okcdiscgolfer
Thank you. Fuel problem is fixed now
Old Oct 6, 2006 | 09:12 AM
jem270's Avatar
jem270
How did you fix it?
Where did you get the parts from?
About how much did it cost?
Old Oct 6, 2006 | 09:15 AM
Rob_1990_Bronco's Avatar
Rob_1990_Bronco
Happened to me a couple years ago.... less then $50 for relay and labor at the shop!!
Old Oct 7, 2006 | 07:21 PM
Okcdiscgolfer
Well... I should say.... I assume it is fixed.
And I am not really sure it was fuel delivery issue since I am now haveing a spark issue.
I did replace the pump because it was starting to get "loud". And I thought it might be indicitive of a pump going out.
Dave
