i was lookin at the 03 compared to the 05's. to pop an 05 grille into an 03 without buyin a modded grille, could i buy an 05 bumper then use a stock 05 grille? it looked to me that the way they made the grilles bigger in the 05-06 years is the made the bumper cutout a little lower. would an 05 bumper fit into my 03 without problems? let me know! Kevin F-350 king ranch
you do not have to change the headlights. you must use a new bumper. the grill will not snap in at the bottom if you keep the old header. you can wire tie it at the bottom like i did on mine. check my gallery lots of pics. its an 01... if you change the header, you must change the headlights becaise the old ones will not bolt in.
