power steering gear swap question?
ok i got a complete front end out from under a 79 f-150 to include coils trailing arms and steering with the gear box. now the question is were the gear boxes mounted further back on the 79's? if so will the pitman arms change over because the truck had a 3" lift on it so the pitman arm from hte 79 was part of a lift kit, and will my steering wheel linkage connect to the input on that gear box or am i gonn have to get something made.
Does the 79 mount on the inside on the frame? I do think that they are very differant. The 72 I think is more look my 66 F-100 4x4, and what I finaly did to get power steering on it, was to put on a Toyota steering box. Or you can try to find a power assist from a mid 70's 4x4, but with that you got that steering ram out frontof the axle.
2323foru
09-16-2012 08:26 PM
Brian085
07-22-2012 10:01 AM
