Project MAN VAN
In other posts, I have addressed my check engine light issue (traced to a an EGR valve/position sensor that works okay 99% of the time). And I think I have that figured out and resolved. But I digress...
Since getting it running mostly right, I defintely want some more pulling power, but don't want to open up the motor or play with the FI system. Since buying the van, I have replaced the plugs, wires, cap, rotor, fuel filter, air filter, and PCV valve. This is what I have in mind for the time being, if there is something more, please chime in
1) remove the air intake "trumpets" as far as I can go and still leave a good sealing lip for the air filter tubing
2) bump timing up to 12 degrees initial
3) replace the exhaust system from the cat back, going to a single 3 inch pipe with free flow muffler and 3 inch tip.
I'm thinking these changes alone will help quite a bit, maybe 20 hp and 30 lb/ft of torque over stock, giving me 265 hp and 410 lb/ft of torque. Since this van is slated for towing a 3000 lb race car on a 2000 lb trailer plus occupants, low end grunt is a big deal.
I'm also looking at revising the cold air intake system, maybe even a hood scoop system.
So, what do you think? Am I on the right track here or am I'm completely in the dark. I don't want killer power increases, but enough to be felt and make my time and effort worth it.
What say you??
Phil
'01 F250 Superduty V10 4x4 x cab
'89 E250 Clubwagon 460
