no one is calculating the minutes of starting and stopping, idling for a little while. these all play into the mph averages, so unless you log exactly how many hours the wheels aren't turning, you'll never know for real. and if you do that, you have WAY too much time on your hands and you need to find a real hobby. lmao.
i hardly look at my hour meter, 980 miles so far on the new one, ready for first oil change.
The hours are total, idling, running down the road, starting, stopped at stop lights, this hole shoot-in match...and you are correct it does add up...to the real MPG.
Tim, what would be the correcion factor used in determining MPG converted from the hour meter? I know someone here posted what Ford used about a year ago.
Hours divided by gallons and then multiply that by X (correction factor)
Think i found the conversion you were looking for.
"2003-2006 Fuel Economy:
Ford vehicles equiped with the 6.0 PowerStroke diesel are not rated for fuel economy by the EPA. If economy is in question, a boost test should be performed. If boost reaches 22-25 PSI in third gear, wide open throttle under load, then th engine s operating normally and no economy related repairs need to be performed. If not in specs, then the engine will need to be diagnosed--check sensor reading, VGT and EGR operation, fuel pressure and quality, crankcase pressure, intake or exhaust restriction, exhaust or CAC leaks. Fuel economy will be affected by many factors, including: excessive idle time (one hour equals approxmately 33 miles of driving), fuel quality and blend, ambient temperature, driving habits, vehicle use, towing, loads, add-on accessories. Broadcast Message 1271; 4450"
25088 / 530.8 = 47.26. I figured my average MPH would be higher as I drive mostly highway 70 - 75 MPH. Got to start making the wife go to the grocery store in her jeep!
