Diesel Kleen Question
Old Oct 4, 2006 | 09:53 AM
schjssj's Avatar
schjssj
I have been using Diesel Kleen in the silver bottle since I purchased my F250 back in August. I live in Michigan and was wondering when would you guys think I should start using the white bottle. How low does the temp have to go for me to start needing it. The truck is ready for winter otherwise, I just installed the block heater cord, the pictures in the tech folder really helped me out. The directions that came with the cord weren't worth the paper they were printed on!
Old Oct 4, 2006 | 11:02 AM
gp42gpw's Avatar
gp42gpw
I switch to White when the temp gets below 32F. I was told you don't really need it until it gets much colder.
Old Oct 4, 2006 | 11:39 AM
TheFist's Avatar
TheFist
What does Diesel Kleen do for you? Just bought my first diesel so I'm new to all this stuff.
Old Oct 4, 2006 | 12:55 PM
rsauve's Avatar
rsauve
I'm also kind of new to owning a Diesel and couldnt find anything in the manual saying to use Diesel kleen. What are the bennefits of using this product.
Old Oct 4, 2006 | 01:10 PM
kw5413's Avatar
kw5413
  • Adds cetane value
  • Cleans
  • Enhanced lubricity
  • Enhances water dispersement
Old Oct 4, 2006 | 02:40 PM
Beachbumcook's Avatar
Beachbumcook
Got Diesel?
Originally Posted by kw5413
  • Adds cetane value
  • Cleans
Remember.... that the white bottle adds "anti-gel" additives that the grey bottle does not and Keith forgot to list as a "benefit" of PowerService.
The cetane boost is greater in the "grey bottle" and they reduce the cetane improves in the white bottle to make room for the "anti-gel" additives.
I use grey until the temps get to around mid 30's on a consistent basis... and sometimes I mix 50/50% anyway to use up the last of the grey stuff that I have still open.
Old Oct 4, 2006 | 02:54 PM
kw5413's Avatar
kw5413
Your are correct.
I don't smoke that stuff in white bottle....so it never crossed my mind.
Old Oct 4, 2006 | 03:37 PM
6.0newbee's Avatar
6.0newbee
Also works great (silver) full strenght for cleaning egr valves.
Old Oct 4, 2006 | 03:59 PM
Beachbumcook
Got Diesel?
What is the "silver stuff"... do you mean the grey bottle we are discussing?
How does it (whatever it is) clean EGR valves?
Here is a cut and paste from their website:
Diesel Kleen® +Cetane Boost® is the premier “performance” product on the market. Diesel Kleen is loaded with cetane, detergency and lubricity additives to keep your diesel engine running at peak performance.
If you are looking for an antigel, Diesel Fuel Supplement +Cetane Boost is the product you should be using. Like Diesel Kleen, Diesel Fuel Supplement contains a cetane and detergency package. However, it is not as concentrated as Diesel Kleen to allow for the superior antigel in Diesel Fuel Supplement.
Ultra Low Sulfur Diesel (ULSD) Compliant — contains less than 15 parts per million (ppm) sulfur
Effective in all diesel fuels, including ULSD and biodiesel
Contains Slickdiesel® for maximum fuel lubrication — protects fuel injectors and pumps against accelerated wear from Low and Ultra Low Sulfur Diesel (ULSD) fuels
Boosts cetane up to 4 numbers — engines run smoother with less power lag, reduced emissions and faster cold starts
Reduces visible exhaust emissions (HC, PM) up to 50 percent and reduces NOx and CO emissions up to 28 percent
Cleans dirty fuel injectors — exceeds Cummins L10 Injector Depositing Test Superior specifications
Decreases fuel consumption up to 8 percent — fuel savings exceed cost of additive
Reduces piston and combustion chamber deposits — reduces soot blow-by and engine oil thickening
Increases power — reduces need for downshifting during high-load conditions
Exceeds industry standards for thermal stability — improves diesel fuel’s resistance to thermal and oxidative degradation
Stabilizes stored fuel
Old Oct 4, 2006 | 06:20 PM
6.0newbee's Avatar
6.0newbee
Ok, Gray bottle. A little color blind. As far as cleaning I was refering to using diesel kleen instead of brake cleaner and other solvents when egr is removed for cleaning. Cleaned mine and it seemed to disolve the carbon and soot real well, back to shiney and almost new looking.
Old Oct 4, 2006 | 07:54 PM
gregk's Avatar
gregk
Would cleaning the egr remove the cricket sound that I hear between 1700 - 2000 rpms after the engine is at operating temperatures? I realized that this has been asked before but I was just wondering about what cleaning the egr would have as a result. Thanks. Haulin350
Old Oct 5, 2006 | 03:28 PM
rsauve's Avatar
rsauve
Thanks for all the info on Diesel kleen. How much is it and how much do you put in per tank full??
Old Oct 5, 2006 | 04:35 PM
TheFist's Avatar
TheFist
I just picked some up a couple hours ago at Wal Mart. If I remember right it was about 15.00 for a 96 ounce bottle that will treat up to 300 gallons.
Old Oct 5, 2006 | 05:09 PM
fgtex's Avatar
fgtex
Same price at Tractor Supply. I put 20 oz. to a 35 gal fillup.
fgtex
Old Oct 5, 2006 | 08:31 PM
Maxium4x4's Avatar
Maxium4x4
Since I have not done so, I want to welcome 6.0newbee and fgtex To FTE.
Read First: https://www.ford-trucks.com/guidelines.html
When cleaning an EGR valve Ford recommends injection cleaner and no brake cleaner. I would think a diesel fuel conditioner would also be safe.
