4wd problems
Old Oct 3, 2006 | 07:38 PM
MBBFord's Avatar
MBBFord
Question 4wd problems
I have a 04 F-150 screw 4x4 that I recently got and when I switch it to 4wd it makes a strange noise, and when I had it at my local ford dealership aligning the front end(just put a leveling kit), and they checked it out, and said it sounds like the 4x4 solenoid/module is going out or is bad... anyone have any problem like this, and know of a fix?
Thanks for any help
Old Oct 3, 2006 | 07:55 PM
Cavtrooper06's Avatar
Cavtrooper06
Yep, there's a TSB out on it. My was bad and the new solenoid fixed it up good.
https://www.ford-trucks.com/tsb/full...hp?tsb=06-8-15
Old Oct 3, 2006 | 09:26 PM
MBBFord's Avatar
MBBFord
Wow, thanks.
I didn't know they had a TSB out for that.
What would I need to do to have ford fix this?
Bring it to the dealership with the copy of the paper showing the link you gave me?
Old Oct 3, 2006 | 09:31 PM
Cavtrooper06
If the truck is under warranty, just explain the problem and maybe even show the TSB. If its not under warranty and your sure your symptoms are the same as listed in the TSB, just buy the solenoid and install yourself. I believe it was either $48 or $68. You may have them show you exactly where its at, it'll take less than 20 mins to change out, at least thats about how long it took my dealer.
Old Oct 4, 2006 | 06:51 AM
96f150's Avatar
96f150
MBB, follow my posts, I just had this done about 2 weeks ago, and then when I got home (it was raining) I opened the hood, and much to my surprise, the way the water was running off the windshield cowl, it was draining right on top of the new solenoid!!!! Well, I went and bent up a nice sheet metal cover to cover the top of the solenoid...problem fixed
Old Oct 4, 2006 | 07:23 AM
MBBFord's Avatar
MBBFord
Ok, where is it located, and do you have a thread about your sittuation, or just fixed it without much problems?
Thanks for the help so far guys.
