1978 - 1996 Big Bronco
Voltage drop across relay normal?
Old Oct 3, 2006 | 11:02 AM
dichdoc's Avatar
dichdoc
I have a fender mounted relay (starter relay/solenoid) that triggers the 12v motor to turn hydarulic pump on snow plow. I have a full 14.5 volts on the battery side and when I trigger it and test on the motor side the voltage drops to near 11 volts is that normal or is the relay shot? Is there a way to test a relay like this? Travis
Old Oct 3, 2006 | 01:36 PM
Bimmerboy1989's Avatar
Bimmerboy1989
Unless the relay has some sort of resitor in it it's not normal for it to drop voltage. a drop in voltage may indicate that the relay is fried.
Old Oct 3, 2006 | 07:26 PM
dwoodler's Avatar
dwoodler
All relays use a little amperage when they are energized but it is just a long stretch of wire so there should be very little voltage drop - no where near 3.5 volts. To prove this theory use either a spare relay you have "just in case" or the starter relay. If you are using the starter relay - pull the starter cable off. Then have someone turn the key to start and see what the drop is there. It should be less than a volt - I'd imagine.
kweiss
Dec 19, 2012 07:12 AM
chuckers98
Electrical Systems/Wiring
13
Feb 14, 2010 10:50 PM
jawmaw
Feb 9, 2009 05:22 PM
Mayne Man
Oct 22, 2007 09:54 PM
jjav8tor
Oct 24, 2004 06:52 PM
