Sponsored by: Real Truck
SRW to DRW ??
Old Sep 30, 2006 | 04:16 PM
bboone52's Avatar
bboone52
SRW to DRW ??
I heard today you can add rear wheels and covert a SRW to a DRW. Is this possible? Practicle? How do you deal with the rear fenders without replacing them or can you? You guys know me by now and that i have a truck camper ( my first) and I am trying to improve the safety and handling. I want to learn all I can before spending any more money.
By the way, I wish I had found you guys 10 months ago. Again, Thanks in advance for your help
Old Sep 30, 2006 | 04:28 PM
EnviroCon's Avatar
EnviroCon
Take a look at these folks. http://www.arrowcraft.com/
Old Sep 30, 2006 | 08:30 PM
PHWLEE's Avatar
PHWLEE
Interesting idea. Not sure how practical it is though. I think it would be easier to swap the whole rear end and flare out the wheel weels / fenders.
Old Sep 30, 2006 | 08:39 PM
shelbymustang's Avatar
shelbymustang
I belive the rear ends are the same if you ever try changing the rear tires on a srw you will find the studs are long enough to add a second set of wheels but you have to deal with the fenders
Old Sep 30, 2006 | 09:35 PM
EnviroCon's Avatar
EnviroCon
Originally Posted by shelbymustang
I belive the rear ends are the same. . .
The dually's come with a much meatier Dana 80, while the SRW's get the Sterling 10.5 rearend. The axles on the DRW are also a different length. If you use a complete kit like the ones Arrowcraft sells it's really not that difficult of a conversion. I would imagine the hardest part would be having the new fenders painted to match the truck.
But, before I spent all that money on a DRW conversion to help with stability while hauling a camper, which it would, given the wider track, I'd consider air springs.
Old Oct 2, 2006 | 10:27 AM
harald's Avatar
harald
The problem with SRW trucks and campers is that you can overload the rear tires, even if you have the highest rated tires on your truck. By nature of having 4 tires to share the load, the dually really shines for camper hauling. I used to carry my camper with a SRW truck, but after checking my weight on the scales at a closed truck weigh station I found out I had over 7000 lbs on my rear axle with tires that were rated for 6830 lbs max.
I traded in my 2 year old truck for a new dually to get that higher weight rating. I probably lost a few thousand by trading in my truck, but the peace of mind was worth it. I suppose I could have gone the Arrowcraft route, but that would have still cost a bunch of money and I still wouldn't have a true dually.
I should note that the stability increase is not much with the dually. The biggest difference on my setup has been adding air springs and Rancho RS9000 shocks, which I also have on my dually.
Old Oct 2, 2006 | 01:42 PM
bboone52's Avatar
bboone52
I checked out the arrowcraft website and gave them a call. It looks like 1700 bucks plus 6 tires if you do not want to carry two spares for the dually conversion. Pretty steep. I have priced Rickson 19.5's and they are 4k for a set of rims and G rated tires. I am now looking at the goodyear website. They have a new Pro -grade Wrangler coming out that I think will be a G grade tire that will fit my stock R16 rims. i emailed them for info so we will see.
If I up my tires from E (3300lb) to G (4500lb) I should be good. right? Harold ??
Also, i looked at air suspensions by Kelderman and Air Ride. They are also very expensive. How good are they?
Old Oct 3, 2006 | 01:42 PM
bboone52's Avatar
bboone52
I had no luck at Goodyear. Their pro grade tires that are coming out only go to an E load range tire in the 16 inch tires. Does anybody make a commercial tire for 16 in wheels???
Old Oct 3, 2006 | 01:44 PM
harald's Avatar
harald
I probably wouldn't have traded my truck in if I could have found a higher rated tire, but the Firestone Steeltex at 3415 lbs is the highest rated tire I could find in 16inch size. Sounds like you might be onto something if Goodyear comes out with a higher rated tire. I would go that route if I were in your shoes.
I imagine a full air suspension would be real nice on our trucks, but I'm sure not going to pay the big $$$$ to install such a system. I'm very happy with the Firestone Ride-rite air springs I have on my truck. They were only a couple hundred (I didn't splurge on the onboard air compressor because I already have one for my air horns). I could seriously overload my truck with those springs on my truck and it'll still sit level and ride nice.
Old Oct 3, 2006 | 02:17 PM
bboone52's Avatar
bboone52
Harold, I think I was sent on a wild goose chase for the G rated Goodyears. I talked to a dealer in Miami and he had all the info on the new Pro grade tires coming out and there was no G rated in the R16's. Sooooo, i guess i am back to the Rickson 19.5's if i want a 4500lb tire, which i do. I posted a thread on tires hoping someone will see it that has a definate answer.
I have air bags but being new to this they were installed inboard of where your firestones are. I am learning to adjust my Ranchero 9000 shocks and the air bags to get the best ride and stability. Finally I am probably going to be a guinia pig and install the Rollguards by Amtech and that will be my final set up i hope.
If you get the chance check out the Amtech website and let me know what you think of the Rollguard System. I have talked to them numerous times and if the Rollguard is half as good as they claim I think I will be in good shape.
