Sponsored by: Auxito
Soft Brake Pedal
Old Oct 2, 2006 | 09:19 PM
Rob-F150's Avatar
Rob-F150
Soft Brake Pedal
The brake pedal on my truck travels more than it should. It's a 97 F150 XLT 4x4 with drums on the back. The engine is 4.6 with automatic transmission (134,000 miles).
I suspect the rear brakes are out of adjustment. Does this sound right?
Thanks, Rob
Old Oct 2, 2006 | 11:10 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
It depends on how far it travels...
My truck has a soft pedal, my parents '99 windstar has an even softer pedal, our '91 Aerostar has a soft pedal, and my dad's '04 F150 company truck has a soft pedal. In fact, on our Aerostar, we replaced both front calipers and went through 3 master cylinders thinking that they were to blame....but nothing changed.
It's the Ford curse...they dont know what good brakes are these days...
Old Oct 3, 2006 | 08:33 PM
Rob-F150's Avatar
Rob-F150
I'll go ahead and inspect all four wheels and look for problems. I'm sure the truck still has the original brake fluid, so I'll flush the brake lines with new fluid.
If I find the problem, I'll post the results.
Rob
Old Nov 1, 2006 | 07:11 PM
wadcock's Avatar
wadcock
I've had my 97 for about 6-7 years now, Always had a soft pedal even after bleeding so me thinks it's the norm.
Old Nov 1, 2006 | 07:43 PM
06f350psd's Avatar
06f350psd
The 98 I own has a soft pedal on it also. but my fathers 92 F150 has pedal that is so touchy that it will through you out of the seat. My 06 F350 has a decent pedal in it.
Old Nov 1, 2006 | 09:55 PM
97F1504X4EC's Avatar
97F1504X4EC
My 97 had soft brake pedal, I replaced all of the brakes and replaced the brake fluid. Once this was all complete my brake pedal feels firm and dose not travel very far. Hope this helps you out.
Old Nov 27, 2006 | 12:16 AM
Walnut4u's Avatar
Walnut4u
I had my 97 worked on @ brake max. No time with work/wife/kids. I had the rotors and drums turned and the system bleed. Got tired of chasing the soft pedal. Went for the easy stuff in the beginning. First; pads, rear pistons, rear brake adjust tool, brake bleed kit from checkers, new spring kit, new fluid, lubed the pins, etc. Minor improvement but still had the soft pedal but the stopping pressure and performance was better. New guy to the F150s. Enjoying it so far! First post to forum.
Old Feb 1, 2007 | 09:07 AM
billet's Avatar
billet
I can't tell if you ever solved your problem but I routinely have to manually adjust the rear brakes on my '98 F150 2WD to bring the pedal back up to the top. The brake pedal feel is then very firm and reassurring. I know the problem is that the automatic adjusters are not working effectively but I haven't pinpointed the cause. I was probably sold the incorrect hardware when I did the brake job. In the meantime, the manual-adjust process takes about 20 minutes and is necessary only once every few months.
Old Feb 1, 2007 | 09:28 PM
wadcock's Avatar
wadcock
I've since did the rear brakes and went with new hardware all around (pads,adjusters,springs,ect.) and it seems to have fixed the problem,. Nice firm pedal since.
Thanks to all
Old Feb 2, 2007 | 03:57 PM
c_cort's Avatar
c_cort
ihad that problem with my truck about 2 weeks ago. then the whole line to rear decided to burst. go ford
Old Feb 2, 2007 | 11:45 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
I wonder how a Hydroboost set-up would work on these trucks? For thoes of you not familiar...the Hydroboost system uses the power steering pump to build up pressure vs. the stock brake booster which operates on engine vaccume.
A brake booster puts about 500-800psi through the brake lines. A hydroboost set-up puts out 2,500psi.
This coupled with a proportioning valve (and a rear disc brake conversion) should give you the braking experience comparable to that of a true sports car.
Old Feb 3, 2007 | 01:06 AM
thehawk789's Avatar
thehawk789
bleed the brakes and check the tension on the rear drums, thats the best you can do.
brake fluid flushes are not necessary.
lube the caliper slides, its good.
PA74F250
Sep 13, 2015 06:30 PM
'75HB250
Jul 24, 2015 11:40 AM
mill666er
Mar 4, 2007 05:16 PM
Rob Capone
Jun 13, 2003 05:47 PM
Dan-79F350
May 17, 2000 03:19 PM
