Coarse spline D60
Old Sep 11, 2015 | 08:45 AM
PA74F250's Avatar
PA74F250
Coarse spline D60
I was under the impression all the later rear D60's were fine spline? Last night I went to rob some brake hardware off the axle of the 78 F250 4wd parts truck I had bought and found it had the old style axles in it.
Old Sep 11, 2015 | 10:45 AM
somethingclever's Avatar
somethingclever
Yes it should have the 30-32 spline (i forget) and not the 16 spline.
maybe it's an earlier axle with moved perches - i think they are date stamped on the housing.
Old Sep 11, 2015 | 10:58 AM
PA74F250's Avatar
PA74F250
I was looking at the perches last night and they look as factory as they get. I didn't look real close for numbers but I'm wondering if the axles and carrier were changed. I would think that stuff was interchangeable between the housings. I just don't know why someone would bother.
Old Sep 11, 2015 | 06:27 PM
Willz74's Avatar
Willz74
A 2wd shouldn't need the perches moved but I don't know if they came with the 16 spline at all after 1972
It should be 30 to my knowledge
Old Sep 11, 2015 | 08:44 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
F250 rear axle Dana 60 16 spline: 1955/74, 1975 before serial number W20,001.
F250 rear axle Dana 60 30 splines: 1975 from serial number W20,001; 1976/79.
Old Sep 11, 2015 | 09:05 PM
PA74F250's Avatar
PA74F250
I'll have to look tomorrow and see if it is date stamped. Just looking at the front axle to the back one my guess would be they were the matched set that came with the truck.
Old Sep 11, 2015 | 10:26 PM
Willz74's Avatar
Willz74
According to number dummy's dates the front if matching would be drums
It won't match because we already found that you have a 2wd rear axle
Old Sep 12, 2015 | 05:23 AM
NumberDummy
2WD/4WD rear axle is the same, the only thing that has to match the front driving axle is the gear ratio.
I edited out 2WD from my previous post, only used it to define rear axle.
Old Sep 12, 2015 | 11:21 AM
PA74F250's Avatar
PA74F250
I tried looking this number up on the Dana website but it wouldn't pull anything up. I've used it before on both D60 fronts I have and it worked so I idk. Maybe someone else can identify it.
Old Sep 12, 2015 | 01:20 PM
NumberDummy
The Dana 60 BOM number (stamped on the axle tube or on an ID tag adjacent to the inspection cover) consists of 6 or 7 numbers, like these examples: 603717-1 or 603717-11.
Ford rear axle ID tag is under 2 of the bolts that retain the inspection cover to the housing.
Old Sep 13, 2015 | 06:30 PM
PA74F250's Avatar
PA74F250
Now that you say that I don't know what I was thinking when I got that number. I do know the tag is long gone so I guess that's the end of the road.
bob_351
Mar 4, 2011 05:59 PM
HIGHBOYSCOTT
May 23, 2009 10:44 AM
Boss50
Oct 17, 2005 04:13 AM
yomow
Aug 31, 2005 07:53 PM
asigalet
May 16, 2005 11:30 AM
