Winter Prep guide
Old Oct 3, 2006 | 10:32 PM
luvemhot's Avatar
luvemhot
not sure what the numbers should be but make sure the batts are seperated
Old Oct 4, 2006 | 12:44 PM
sneak's Avatar
sneak
Truthfuly you should load test both of your batteries seprately. That will give you the only real idea of what kind of shape that they are actually in.
Old Oct 4, 2006 | 03:14 PM
ponch37300's Avatar
ponch37300
Does anyone know what the voltage is that i should be getting to tell if these batteries need to be replaced.
Old Oct 4, 2006 | 04:09 PM
sneal's Avatar
sneal
Too old for this
It takes a special battery tester to do it. Go to the local auto parts store and they can do it for you. General rule...3 to 5 years is all you get, yes some last longer and some not so long depending on useage and enviroment. Have no clue on gpr reading.
Old Oct 4, 2006 | 04:51 PM
Spamjohnson's Avatar
Spamjohnson
A reminder, with a 500 mile range, if you are running Georgia Fuel and head up north, remember to Fuel up perodically with local winterized fuel. Otherwise you might have problems when you hit Maine.
http://tdiclub.com/TDIFAQ/TDiFAQ-10.html
Graph stolen from the TDI club
Sam 1999PSD350CCLB Minnesota
Old Oct 4, 2006 | 11:56 PM
ryaneverk2's Avatar
ryaneverk2
You can't quite tell with a standard voltmeter. A low voltage reading (below 12 or 12.5) could just mean the battery has been drained and not recharged (headlights left on overnight or something like that). The way to tell if it needs replacing is to take it to a place like Autozone where they have a machine they'll hook to it that will place a load on them and see how it performs. If you have them test yours, make sure they're tested individually (and not hooked up to each other at the time, I think).
Old Oct 5, 2006 | 10:41 AM
doc526's Avatar
doc526
mjlewis, Im not too far from you, I live in Dallas, GA. I have not had a problem starting my 7.3 in the past few winters that (I have owned it) without plugging the heater in. I run the 15W-40 Shell Rotella year round and occasionally run a bottle of Diesel Kleen in the tank. Due to some hard starting during the summer, I replaced the batteries. (The orginal ones were 6 years old anyway) The other thing I did do before winter was purchsase the coolant test strips from a local Napa store. I was curious of the SCA levels and freeze point of the antifreeze. Hope this helps.
DEAN
Old Oct 5, 2006 | 08:39 PM
rjmay's Avatar
rjmay
additional winter idea
Like others, I use syn oil and block heater on for 2 hours.
I added a battery charger and wired together with block heater.
Ran a former extension cord under the frame to the rear bumper because I like to pull out each morning rather than backing out.
Just hitting those batteries with a charge prior to use brings up battery temp.
There is a great chart somewhere showing real battery CCA decreasing with temperature dropping.
Banage
General Diesel Discussion
Nov 2, 2013 11:01 PM
Opossum
Nov 19, 2012 05:30 PM
EGRParanoia
Feb 16, 2010 10:30 AM
from way up north
All Things Towing
Jan 17, 2010 08:43 PM
ch11
Alaska Chapter
15
Jul 19, 2005 04:02 PM
