Alt Wiring Help Please
Old Oct 2, 2006 | 08:29 PM
dv_shane's Avatar
dv_shane
I Have A 94 F-150 5.0liter
Removed The Ford Alt Due To Not Enough Amps.
I Have A Ac-delco 125 Amp Alt It Has A Plug With 2 Wires Marked A" & B"
I Took The Wire From B" And Jumped It To The Batt. Post On The Alt I Found That Much On Line.
Now What I Need To Know Is The Wire From A" Term Plug Goes To Where?
Then I Took The Big Batt. Wire From Alt And Put It On The Same On The Ac-delco
My Truck Wiring Has A Plug With 2 Wires One Is Red\green The Other Is Yellow I Think. Then There Is A Single Wire Plug With A White\blk Wire
What Do I Do And How Does All These Hook Up Thanks For The Help I Know It Has To Be Simple I Just Dont See It
Old Oct 2, 2006 | 10:35 PM
Franklin2's Avatar
Franklin2
Hook the red/green to the "A" terminal on your new alt, and you should be set.
Old Oct 2, 2006 | 10:51 PM
dv_shane's Avatar
dv_shane
thanks that is what i did. then i just taped off the yellow and white.
seems to be working i turned on headlites and my cooling fans at idle was putting out 13.25 volts and drawing 17 amps
thanks again dave
A/Ox4
Feb 11, 2014 09:22 AM
Pitcrw6
Aug 26, 2012 12:59 PM
Slankky
Aug 19, 2012 02:02 PM
82StepEffie
13
Mar 7, 2005 04:25 AM
doug84xlt
Jan 30, 2004 03:04 PM
