Rear end leak
Old Oct 2, 2006 | 08:20 PM
1954blueoval's Avatar
1954blueoval
Rear end leak
I have a 9 inch rear end in my truck and I have had an ongoing problem for a while. I have gear oil leaking out the right tube and into the break drum. It covers everything and is thrown all along the inside of the fender.
I replaced bearings, seals, gaskets, and used a whole lot of RTV and it still leaks. Anyone have any ideas or solutions to similar problems?
Old Oct 2, 2006 | 08:41 PM
wickymustang's Avatar
wickymustang
Have you seen if the tube that the bearing is put into is true (round). Was this the original rear end or no?
Old Oct 10, 2006 | 10:09 PM
1954blueoval
It's not the original rearend. I found out that Currie and Moser make an axle bearing with an o-ring built into the outside diameter. I think I am going to try this.
Ronnief150man
Jan 2, 2017 06:35 PM
Castiron2007
Nov 21, 2016 07:03 PM
jofes
Nov 5, 2016 09:26 PM
niagrademon
Nov 10, 2012 07:11 PM
