Newest Block
Old Oct 2, 2006 | 06:14 PM
kenz28's Avatar
kenz28
Newest Block
Hey All,
What is the newest block (302) that can be rebuilt with a regular intake and 4bl carb?
Having alot of trouble finding a good block with good (not broken) main caps.
Trying to keep the machine work to a minimum.
KenZ28
Old Oct 2, 2006 | 10:03 PM
Conanski's Avatar
Conanski
All 302(5.0) motors can be setup with a carb...
Old Oct 3, 2006 | 06:34 PM
kenz28's Avatar
kenz28
So all the blocks are the same, to include the roller motors (not looking for these unless they are the same).
Thanks
KenZ28
Old Oct 3, 2006 | 08:05 PM
TigerDan's Avatar
TigerDan
Yes, you could take something as new as a roller motor from a late 90's 5.0 Explorer and change the distributor, replace the manifold and all EFI components with a carb and carbed manifold. So don't rule out late model roller motors in your search.
If you want to go with a whole engine, the '87-'93 5.0 HO is one of the best. If a block is all you're after, you need to make sure you have a crank that will match the block. Pre-1981 302s had a two-piece rear main seal and used an imbalance factor of 28oz. while post-'81s had a one-piece rear main seal and ised a 50oz. imbalance. So you can't use a an early crank in a late block.
What year 302 are you working with?
Old Oct 4, 2006 | 09:44 PM
scottie2hottie's Avatar
scottie2hottie
i have an 87 EFI motor with a carb setting on it right now. It's extremely easy if you have the stuff to do it. Not a fan of the EFI heads though. I switched mine out for a set from a late model 4v 351W
Old Oct 5, 2006 | 07:15 PM
kenz28's Avatar
kenz28
Hey Scottie2hottie,
Anything special about swapping a EFI to a carb or is it a simple intake and carb swap?
All help appreciated,
Thanks
KenZ28
Old Oct 5, 2006 | 09:56 PM
scottie2hottie
need to swap distributors too- you can run points or duraspark- but no EFI distributor, i went with duraspark because it's what I had. They also have HEI distributors for them from procomp for $100 brand new on ebay. That is my next investment. One wire hook-up. IMO EFI to carb is very easy on these 302's. I have done 2 in my life. EFI is nice but once it goes it's hard to catch back up with. I like the simplicity of a carburetor....probably will always prefer it.
Old Oct 7, 2006 | 07:29 AM
kenz28's Avatar
kenz28
Thanks Scottie2hottie
KenZ28
