Our local Fire Department purchased a 1964? Ford 100 Custom Cab new off a dealer lot. Info off the plate is F110E640123 W.B.120 Color J Model F110, Body E81 Trans N Axle 08 Max GVW 6600 Co HP 172 RPM 4000 D.S.O. 121901. It has 11,085 miles, stored inside. Is now yellow, looks to be originally red. It is now a brush truck, and appears to be easily returned as new stock (a few holes here and there for mounting of equipment.) It is a V-8, 4x4, 4 speed on the floor. Little rust. Can someone 1. Is this really a stock truck? Can you help decipher the plate info? Any idea of value (as we will be retiring it soon and selling at bid.)
Thanks,
George
ilauravi@rochester.rr.com
George, from the #s you posted, Id say you have a 65. Here is what I came up with:
-F11=F100 4x4
-O (are you sure this in not a D=352 v8)
-E=Assembly plant Mahwah ,NJ
-Trans N= 4spd manual (65 is the only year showing N code)
-Axle 08= 3.50-1
Not sure about the rest. Where is the truck located. I may be interested.
