Sponsored by: Auxito
what just happened?
Old Oct 3, 2006 | 08:39 PM
tenpin's Avatar
tenpin
Anyone have an other thoughts?
Old Oct 3, 2006 | 08:52 PM
kharmaguru's Avatar
kharmaguru
just that by the same premise the wire could be bad.
Old Oct 4, 2006 | 04:43 AM
tenpin's Avatar
tenpin
I checked the wire and it was 1.8 omhs, just like the others.
Old Oct 4, 2006 | 08:38 AM
tenpin's Avatar
tenpin
What tells the coil to spark? Could my computer be bad?
Old Oct 4, 2006 | 09:03 AM
Gibson13601's Avatar
Gibson13601
Have you swapped in the new plug yet?
Old Oct 4, 2006 | 09:47 AM
tenpin's Avatar
tenpin
Yes, and still no spark for # 8 Thanks.
Old Oct 4, 2006 | 11:56 AM
Gibson13601
Check (all) your fuses before considering a bad PCM.
Old Oct 4, 2006 | 05:12 PM
tenpin's Avatar
tenpin
I just changed to coil and that took care of it. Thanks to all.
Old Oct 4, 2006 | 05:20 PM
Gibson13601
Congrats....Great job. Sometimes our truck issues take alot of time and money to investigate. But you did well. Now go tackle your EGR issue. Here is what I went through with my p0401. Almost considerd suicide. LOL.. heres the link and good luck keep us posted. https://www.ford-trucks.com/forums/5...cer.html?pp=15
Old Oct 4, 2006 | 08:14 PM
zman764's Avatar
zman764
Gibson I"m too lazy / busy to read you entire link so I am going to sum up what I did to my truck, even thought it may be the same as your link.
Basically one of the most common cures for the P0401 is pull off the T-body and elbow that go into intake manifold. On the side of the elbow there are 2 ports that the EGR lets exhaust gas into the intake through. Those ports are most likely clogged and look like stalagtites sticking through them. Get all the carbon out, pick it out and use a brake cleaner or T-body cleaner something along those lines. It is simple pull off the 4.6L/5.4L cover over the Tbody pull off all the hoses for emissions crap. Remeber where they go but each one will only go into one place. Then there were I think 4 bolts holding the T-body & Elbow on. Take the wire for the T-body that runs to the gas pedal off also remember how it came off. Really simple 30 min max job. GOOD luck, glad to hear it was just a bad coil.
Old Oct 4, 2006 | 08:17 PM
Gibson13601
My problem is fixed dude....LOL....thanks though....I guess?????
Old Oct 4, 2006 | 08:18 PM
zman764's Avatar
zman764
I was postin that for tenpin. Because I wasn't sure if your link was the same thing I put up or not. I just didn't feel like reading everything on your link so I wrote what I knew it might be. Ha Ha
Old Oct 4, 2006 | 08:28 PM
  #28
Gibson13601
Its all good ...Peace
