Engine revs when I put it in gear
Old Oct 2, 2006 | 10:13 AM
KJKozak2's Avatar
KJKozak2
78 F150 4x4 460/c6/Holley 750
I had the truck out this weekend and had a bizzare problem. With my foot on the brake and the truck in gear, the engine revs up by 200-300 RPM. Sometimes it does it in park, but only once in a while, and it never did it in reverse.
A bad brake booster was suggested so I disconnected it and plugged the vac port. It still happened. I disconnected the brake booster, tranny vac line, vac advance and plugged all the ports/hoses and it STILL does it. The only vac line that stayed connected was the PCV. All the ports on the carb are plugged, too
I even looked for weird stuff like broken motor mounts, pinched lines etc...
Anyone have any ideas on what might cause this or what else I can try to find the problem?
Thanks in advance!
Kevin K.
Old Oct 2, 2006 | 08:54 PM
rjb2z's Avatar
rjb2z
I spent this last weekend dealing with the same problem on my 77 f100/351W/600 Holley. Tried all the same things you did, no luck (thought it had to be the booster--but it wasn't). Hopefully somebody's solved this one before.
Old Oct 3, 2006 | 09:28 AM
beartracks's Avatar
beartracks
Sounds like linkage interference somewhere catching the throttle?
Old Oct 3, 2006 | 09:36 AM
KJKozak2's Avatar
KJKozak2
Already thought of that and no dice. I have a homemade floor shifter that goes directly to the tranny and it's nowhere near the throttle. Thanks for the reply though.
I thought maybe the motor mounts were bad causing the engine to tilt and rev the trottle, but that doesn't seem to be happening either.
Kevin K.
Old Oct 3, 2006 | 10:47 AM
LxMan1's Avatar
LxMan1
Something has to be moving. If the linkage is adjusted too tight, a small amount of engine movement will cause the linkage to move and open the accelerator.
Tranny mount perhaps? It will let the tailshaft rise which tilts the engine forward and will allow the linkage to pull on the carb.
Old Oct 3, 2006 | 11:02 AM
KJKozak2's Avatar
KJKozak2
I did look for that stuff, but I'll check again. I've been thinking it's a vacuum leak somewhere (maybe in the tranny), but I can't seem to find one.
Thanks!
Kevin K.
Old Oct 3, 2006 | 12:07 PM
buzzbait65's Avatar
buzzbait65
disconnect the carb linkage and see if it still does it........
Old Oct 3, 2006 | 12:19 PM
Torque1st's Avatar
Torque1st
Posting Legend
Loose carb?
Old Oct 3, 2006 | 03:13 PM
KJKozak2's Avatar
KJKozak2
Never thought of disconnecting the carb linkage. Good idea! Thanks.
Carb is tight. Checked that too. Thanks.
K.
Old Oct 4, 2006 | 03:49 PM
KJKozak2's Avatar
KJKozak2
I disconnected the linkage last night and it seemed to solve the problem. I loosened it up and reconnected it and all seems ok. Since it's an intermittent problem, I can't be sure it's fixed until I do a full scale off-road test.
Thanks for the suggestions all!
Kevin K.
Old Oct 4, 2006 | 03:56 PM
Mil1ion's Avatar
Mil1ion
Make sure you have two return springs on that accelerator linkage
Old Oct 4, 2006 | 04:00 PM
KJKozak2's Avatar
KJKozak2
Thanks Dennis. I learned that lesson a long time ago (the hard way). I think I have 3 on there now.
K.
Old Oct 4, 2006 | 07:18 PM
Troy77+79's Avatar
Troy77+79
Not to barge in on this thread, but why do you need two return springs? Is it to prevent a stuck throttle? My truck had two when I bought it, but it made the pedal too stiff and I removed one. Should I put it back?
Old Oct 4, 2006 | 07:25 PM
Mil1ion's Avatar
Mil1ion
In case ONE of them breaks.
If you only have one of them and it breaks, guess what happens
Old Oct 4, 2006 | 08:30 PM
SwOkcOffRoader's Avatar
SwOkcOffRoader
i only have one on my Holley, but the carb itself also has a really good spring on the throttle rod, so i guess i technically have 2...i consider the long spring the backup spring, since the carb really dont need it to close properly, but i would never think of running without it....
