VSS or RABS
Old Oct 1, 2006 | 11:50 PM
DYDF250's Avatar
DYDF250
VSS or RABS
Hey,
I have a problem with the discriptions that I have been reading on the forum about the vechile speed sensor or the rear ABS controler sensor?
I had a problem with my truck a few months ago, all the signs that the " VSS "
had gone. This is what I was told on the forum, I want to add that I want to clear up what is what to us all. The part is/was the RABS and not the VSS.
RABS is located on the rear diff. Part replaced problem fixed
Now,new problem/throwing a code ,OD light flashing, tech says VSS. I want to know does my 95 f250 have a VSS on the trans and what do I need to tell my parts person?? Where do I look for the VSS on the trans?
Old Oct 2, 2006 | 05:19 AM
Cuda_jim's Avatar
Cuda_jim
The sensor in the rear diff is called both a VSS and RABS sensor in the Ford factory service manual. Some sensors serve more than 1 function.
You need to do more investigating if the VSS/RABS sensor is new. Check the plug/wire harness going to the sensor.
How long was it fixed?
Is the trans shifting OK?
Is it stopping OK?
Clear the code and see if it returns.
Old Oct 2, 2006 | 10:02 AM
DYDF250's Avatar
DYDF250
Cuda_jim
My ford dealer says only a RABS on the diff, yes, I know the sensor controls a bunch.
Do I have a VSS on the transmission?
Two months ago changed out the RABS
Shifting good
Stopping great
Old Oct 26, 2006 | 06:02 PM
NWBronco's Avatar
NWBronco
It's one and the same. Signal is split, goes to ABS controller for braking control and PSOM for speed/transmission control. Dealer is blowing smoke and not driving an oil burner.
Bob K.
Rentaro
Feb 18, 2016 03:15 AM
teddynaegele
Sep 26, 2015 03:47 PM
1979kent
16
Jan 31, 2012 05:21 PM
empiretc
24
Jul 12, 2007 10:49 PM
rrobb
Jun 19, 2006 06:23 PM
