1978 - 1996 Big Bronco
idle when warm
Old Oct 1, 2006 | 09:33 PM
4radiokid's Avatar
4radiokid
idle when warm
1990 5.8 e40d Start up when engine is cold is normal, engine will go to fast idle and after awhile it will drop to 650 rpm. Any start after that when engine is warm the idle will go up to 2000 rpm and slowly go down to about 1200, I have to bump the throttle several times to get it to drop to 650 rpm. It has a new tps adjusted at .8 volts at closed throttle and a new iac. Any ideas? thank you.
Old Oct 1, 2006 | 09:36 PM
chrono4's Avatar
chrono4
before you throw any parts at it, pull the codes off it so you know where to start at. www.fordfuelinjection.com
