6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
2008 f-450 vs f-350
Old 11-12-2006, 09:09 PM
shadetree01's Avatar
shadetree01
shadetree01 is offline
2008 f-450 vs f-350
Does anyone know the bed height diffirence between the 450 and the 350. I am referring to the top of the bed rails on both in 2wd if possible if not 4wd will do. I know on the old 450 when they would put a normal pickup bed on it, unless it was cut down they were always to high to pull a fifth wheel trailer with enough clearance between the bed rails and trailer. Alot of people would leave the trailer nose high which is not really a fix to the problem it just dumps all the weight on the back axle.
Old 11-12-2006, 11:03 PM
greenham64's Avatar
greenham64
greenham64 is offline
well one of the main advertising points is able to pull a 24k lb fifth wheel. I would suspect whatever the problem with height in the past may have been, it has been resolved. That is the 450 4wd that they have been promoting fyi.
