bed rail caps
Old Nov 10, 2000 | 09:03 AM
ned's Avatar
ned
bed rail caps
Does anyone know where i might find bed rail caps for the front,sides and tailgate for a 1961-1965,8 ft.2wd bed.thanks!
Old Nov 10, 2000 | 06:01 PM
jowilker's Avatar
jowilker
bed rail caps
Would you like to better define what you are tslking about?
I can tell you there aren't many things out there for the 61 - 66 beds. You may get some later year models that will work.
John
jowilker
66 F100s
In the still cool hours of the night, you can hear chevys rusting away.
Old Nov 10, 2000 | 08:43 PM
dave186's Avatar
dave186
bed rail caps
I think he is talking about the diamond plate aluminum things that protect the sides of your bed. and if anybody nows where to get them for a 73-79 let me know, I see lots of trucks with them but I cant find them.
Dave
http://home.earthlink.net/~dave186/DMPbanner1.jpg
http://www.davesmonsterpit.com
Old Nov 10, 2000 | 09:46 PM
ned's Avatar
ned
bed rail caps
yep,thats what i am looking for! They come in vinyl,steel,diamond plate and everything else.my1961 4wd gets used every day as a work truck maybe someone has found something that would fit from a newer model.thanks!
Old Nov 10, 2000 | 10:11 PM
dust3's Avatar
dust3
bed rail caps
Dave, DeeZee makes checkerplate aluminum bed caps for'73-'79 trucks. Willmore also makes Stainless bed caps for that same application, I have a set on my truck and they look and fit very good. Ned, i believe there was a post on this about a week ago and I have looked through the majority of my suppliers catalogues and have found nothing for your body style. :-( One option you may want to look at is having the topsides of your rails sprayed with spray-in boxliner. Any spray-in boxliner dealer should be able to do this for you for about the cost of bed caps and it will be just as durable. just a thought. :-)
Dustin
Old Nov 11, 2000 | 01:35 PM
73Custom's Avatar
73Custom
bed rail caps
[font color=red size=3]Another option, you might check with a metal worker or welding shop, see if they can get some aluminum and make you some. It's just a long strip with a 90deg bend on one side (they have machines that do that perfectly) and a shallower bend on the other.
I used to work at a welding shop with metal fabrication equipment, we made a set out of steel diamond plate and then painted them (aluminum would be better IMO).
Just a thought...
Marty[/font]
Old Nov 12, 2000 | 10:56 PM
cams69's Avatar
cams69
bed rail caps
