Hesitation on acceleration..
Old Sep 29, 2006 | 10:33 AM
MyTruckOfDeath's Avatar
MyTruckOfDeath
I just noticed that it's been 3 years since I've posted! But the good news is that I still have the same 1972 F100 .. Yeah!
** The problem I'm having now, is that I can't get the hesitation out of my truck when i take off from a stop. This happens when the engine is hot, cold, warm, etc.. I'm not sure if I just need new plugs and a tune up or what.. I have insalled new points, and entire new dist shaft, new spark plug cables, but there it still is...
Thanks, it's good to be back..!
Mike
Old Sep 29, 2006 | 11:17 AM
bertha66's Avatar
bertha66
Look down into the carb and see if you are getting a good squirt of fuel from the accelerator pump. There is a ajustment on the linkage to get more or less of a squrit as needed.
Old Sep 29, 2006 | 01:29 PM
fordxxx's Avatar
fordxxx
My 302 used to do that until I advanced the timing a bit...then the hesitation went away.
Old Sep 30, 2006 | 12:40 PM
thesprocket26's Avatar
thesprocket26
I second the accelerator pump. Carb rebuild time.
Old Sep 30, 2006 | 02:13 PM
Mil1ion's Avatar
Mil1ion
To be clear.
Is it hesitation or a stutter ?
People mix these terms up.
Hesitation is a ...no power...then quickly.... power
stutter is basically ..it stutters or stumbes to finally achieve power.
These are caused by different things
Old Oct 26, 2006 | 08:36 PM
JWadeSchutt's Avatar
JWadeSchutt
I have had the same problem on my '69 w/ a 390 and it is a studder. I have tried adjustment on the carb and on the timing. Do you think it could be the stock manifold? I have questioned this because i bought the truck a year ago and it had been bored out and had a cam in it. So could it be that it needs to be upgraded to a performer intake?
Robrt32
Feb 12, 2014 07:57 PM
bengerman
Nov 11, 2012 04:52 PM
granitepro78
1997 - 2003 F150
Oct 13, 2012 12:07 PM
schmidty99
Aug 18, 2004 08:16 AM
nolanc2
Jan 22, 2003 10:50 AM
