Manual Brakes to Power Brakes
I've been considering switching to Power Brakes on my 79 300/6. I can find just one vacuum source large enough, and that's the one currently feeding the PCV valve. Should I just tee into that line to supply the Booster ? If so, then it would probably be a good idea to replace the PCV grommet on the valve cover, as the original one is showing it's age.
Many thanks !
Many thanks !
