Missfire
Old Sep 26, 2006 | 05:54 PM
javan's Avatar
javan
Missfire
hello i have a 92 f-150 4x4 with the i6 that is only fireing on cyl 2-4-6 do you have any idia why 1-3-5 arnt . all six have spark what sensor controls injectors
Old Sep 28, 2006 | 02:34 PM
F-150battlemaster's Avatar
F-150battlemaster
OMG....
Try replacing the cap and rotor for starters.
Old Sep 28, 2006 | 02:55 PM
Ranger GT2's Avatar
Ranger GT2
Is your check engine light on? With it running that poorly I would think you would have some kind of check engine code.
Your computer controls the fuel injectors.
Old Sep 28, 2006 | 10:21 PM
javan's Avatar
javan
i have changed cap , rotor , plugs and wires
injectors 1-3-5 arnt getting ground pulse from computer
codes are
412-cant control rpm during test
116-engine coolant temperature (ect) sensor-signal voltage too high or low
172-heatedexhaust gas oxygen (hego) sensor-voltage signal indicates "lean" (bank 1)
213-spark output (spout) circuit-open connection failure
332-insufficient egr flow detected
can any one tell me what i might have to replace without doing everything dont have a lot of cash to fix
thanks for any and all help
Old Sep 29, 2006 | 02:57 PM
Ranger GT2's Avatar
Ranger GT2
Do you have a TFI type distributor? The spout code usaully means that there is a problem with in your distributor if I remember right. You have a lot of different areas that are giving out codes. Make sure that your thermastat and coolant temperature sensors working right also. You may try post this in the electrical forum, I have used it a few times and they were very helpfull.
Old Sep 29, 2006 | 04:00 PM
Silver Streak's Avatar
Silver Streak
Injectors 1,3 and 5 are all on bank one and are batch fired. See if you have power on the red wires, which you probably do since the other injectors are working. Then check the resistance of the tan/org wire between the injectors and pin 58 at the PCM. It should be less than 1 ohm. If that's good, connect a test light between pin 58 and a known good power source. If it won't light while cranking or running the PCM is bad.
