Flasher
Old Sep 28, 2006 | 10:17 PM
NDL's Avatar
NDL
Flasher
The turn signal on my 2001 Ranger is driving me crazy. All of the bulbs are fine, yet the turn signal is flashing at a ridiculously fast pace.
Assuming that the Ranger used a standard flasher, I was simply going to replace my current flasher, with another one. Yet, I found out that the Ranger uses a more sophisticated flasher design, which some say can be adjusted?
Anyone know if this is so, or would replacing the flasher be my best bet? Also, do I have to remove any trim panels, or is the flasher accessible from underneath the dash?
Thanks in advance
Old Sep 29, 2006 | 01:10 AM
CheapRanger's Avatar
CheapRanger
Is it fast when you turn it both right and left? If yes then I'd try a flasher.
If no, and you say the bulbs are "fine", I am assuming you mean they visably flash from the outside; did you replace one recently? (may be wrong number, which could do that).
The flasher is normally around the fuse box, (I believe under the drivers dash, but I don't have a 2001).
Old Sep 29, 2006 | 10:25 AM
NDL's Avatar
NDL
Thanks for your suggestions. Since it's both the right and left signals, you're probably right; a simple flasher replacement will do the trick.
